Kevin Wiles Posted March 1, 2008 Share Posted March 1, 2008 sometimes when i crank the coke machine (427 w/ quadrajet) it will spit and sputter and backfire like crazy. when i lift the hood I see that the problem is that the choke is on. I lift the linkage from the little coil that sits on the intake, and it begins to run great. problem is, as soon as any gas is given, it goes back to choke. (1/2 choke or so) So the only way to get it to run right is to tie the choke open, basically disabling it. what can i do to make it operate correctly? Link to comment Share on other sites More sharing options...
Guest ADGTRUNKLID Posted March 1, 2008 Share Posted March 1, 2008 I would say sit back and have a Pepsi while it warms up Perhaps a new spring is in order? Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 1, 2008 Share Posted March 1, 2008 what about the choke pull-off (vacuum diaphragm) Link to comment Share on other sites More sharing options...
Mike 57 Posted March 1, 2008 Share Posted March 1, 2008 I think Sam hit it right on the head. The choke unloader is probably shot the diaphragm is most likely leaking and and not able to open the choke once the engine starts. Link to comment Share on other sites More sharing options...
7tonemonte Posted March 1, 2008 Share Posted March 1, 2008 That was the problem with my Olds, nothing a screwdriver in the carb couldnt fix!! Once that was taken care of and fixed, it was good as new. You could always go manual choke on it Link to comment Share on other sites More sharing options...
kc8oye Posted March 1, 2008 Share Posted March 1, 2008 i agree, sounds like the vacuum diaphragm isn't pulling the choke open when the engine fires.. make sure it's attached to a manifold vacuum nipple and not a ported Link to comment Share on other sites More sharing options...
