Monte123 Posted January 3, 2021 Share Posted January 3, 2021 I am converting from auto to standard, is the location for the z bar bracket pre drilled on the frame or do I have to “locate” it. This is for a 72 Quote Link to comment Share on other sites More sharing options...
Mike Brichta Posted January 3, 2021 Share Posted January 3, 2021 When I converted my 72, the holes were already in the frame. No drilling was required. Good luck!! Mike Quote Link to comment Share on other sites More sharing options...
MCfan Posted January 3, 2021 Share Posted January 3, 2021 Hey, Tony, I've attached a couple of photos of pages in from the '70 Factory Assembly Manual that may be useful to you as I doubt the '72 was any different. The stud that goes into the block casting boss just forward of the bell housing will position that end of the Z-bar and will also help locate the bracket on the other end if you keep the Z- bar pivot shaft perpendicular to the centerline of your motor. As shown in Section A of the assembly drawing, the bracket is placed close to the outside edge of the frame (as it is also on my '70 factory 4-speed). One of the last auto-to-manual conversions I remember reading about on this forum was done by Murray Rehder on his '71 small block about 3 years ago. You might want to send him a Private Message at his club ID which is "Murphy" if you have specific questions on this conversion for a first gen Monte. Also, here's a link to a thread less than two years ago asking who has first gens with manual transmissions: https://www.firstgenmc.com/forums/index.php?/topic/19613-manual-transmission-montes/&tab=comments#comment-199974 You might be able to find some other contacts there if you need them. Good luck. Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 3, 2021 Share Posted January 3, 2021 5 hours ago, Mike Brichta said: When I converted my 72, the holes were already in the frame. No drilling was required. Good luck!! Mike Same when I did my old '72 Custom years ago, first with the LT1 350, then the LS6 454, no issues that I recall. Bolt in parts from a Chevelle I thought. Holes are already in the frame. Quote Link to comment Share on other sites More sharing options...
Mike Brichta Posted January 3, 2021 Share Posted January 3, 2021 Actually if I remember correctly, the frame bracket for the Chevelle/El Camino and Monte are different. Can someone else confirm? Mike Quote Link to comment Share on other sites More sharing options...
Monte123 Posted January 3, 2021 Author Share Posted January 3, 2021 Thank you all, yes, the bracket is different but I do have it. I apologize, I did not look before asking the question. The holes are in the frame. Looks like the proportioning valve may have to move. Will keep you posted. I have to get it running and move it over to a buddy's. Bought a 5 speed kit from SST for it Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 3, 2021 Share Posted January 3, 2021 This place below says the part number 3972641 (item #7 in diagram) is specific to 70-72 Monte's too. Maybe I got one from a dealer years ago when I built that car, or modified a Chevelle one to fit? I still have the Z-bar up in the attic, but must have left that bracket on the frame, or misplaced it because it's not with the Z-bar/bellhousing/shifter, etc. https://www.4speedconversions.com/3972641.html https://www.4speedconversions.com/3972641_r1.html https://www.chevelles.com/threads/4-speed-conversion.67031/ Quote Link to comment Share on other sites More sharing options...
