DDay Posted July 23, 2008 Share Posted July 23, 2008 Can you guys tell me if it is fairly easy to install a 4speed.Already have buckets and console. Quote Link to comment Share on other sites More sharing options...
Heckeng Posted July 23, 2008 Share Posted July 23, 2008 I think it can be a little work. There are several guys on the forum that have converted though, they'll have good info for you. You need to start collecting all of the parts you'll need, and I believe you need to weld in a small "hump" into the floorpan for the shifter. Leo Konik of Konic's Classics can help you with the parts. Phone: (810) 329-6868 (Michigan) E-mail: koniksklassiks@sbcglobal.net Web Page: www.koniksklassiks.com Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 23, 2008 Share Posted July 23, 2008 the frame mount for the "Z" bar is monte only piece, if you use a factory shifter, you will need a factory 4 speed crossmember too, the cluth pedels/linkage is avaiable aftermarket Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted July 23, 2008 Share Posted July 23, 2008 It was fairly easy with mine. I got all the parts out of a 69 Chevelle SS. I had to use the Monte drive shaft with the front yolk off the Chevelle drive shaft.Everything bolted up and I was able to use the Monte speedo cable although it is about 8 MPH off! Mike Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted July 23, 2008 Share Posted July 23, 2008 I did not have to change the crossmember but did need to change the mount. Mike Quote Link to comment Share on other sites More sharing options...
DDay Posted July 24, 2008 Author Share Posted July 24, 2008 thank guy's still looking into it.. Quote Link to comment Share on other sites More sharing options...
Andreas Posted July 25, 2008 Share Posted July 25, 2008 You will also change the flexplate on the engine to a flywheel and install a clutch... Quote Link to comment Share on other sites More sharing options...
Archer Posted July 29, 2008 Share Posted July 29, 2008 Don't forget the issues with the Pilot bearing. that willbe the hardest part of the conversion. Assuming your crank wasn't fitted already. Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted July 29, 2008 Share Posted July 29, 2008 My stock crank was the right size for the pilot bushing. I'am telling ya it was the easyest conversion i ever did! Mike Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 29, 2008 Share Posted July 29, 2008 I've done a few 4 spd conversions in my younger days, never had a issue with installing a pilot bearing/bushing Quote Link to comment Share on other sites More sharing options...
