Denny Posted December 16, 2023 Share Posted December 16, 2023 Has anyone restored derby caps,I have several trying to find the best way to redo the black painted areas.I have restored some side trim for my 70 c10 by spraying the entire piece and wiping the high areas with a gas saturated rag which worked but don't think that technique would work for these. Any advice appreciated. thanks Quote Link to comment Share on other sites More sharing options...
willie Posted December 16, 2023 Share Posted December 16, 2023 Denny maybe you can tape large areas and someone here said once, use grease or Vaseline on the tight areas with a Q-Tip. I never did derby caps so i cant tell you from personal experience. Maybe someone else that did do it can chime in and let us know what they did. Good Luck Quote Link to comment Share on other sites More sharing options...
overdrive Posted December 16, 2023 Share Posted December 16, 2023 I take the center off the base and wash, then degrease. Masking tape and a razor blade. It's tedious work, but they come out great. Dan 2 Quote Link to comment Share on other sites More sharing options...
Marks71 Posted December 16, 2023 Share Posted December 16, 2023 I be used 1/4” masking tape and individually taped each rib making sure the tape is tucked in the corner at the base of the rib. Then cut the tape with a razor, Xacto knife, or one of those small retractable knives where when they get dull you break off the tip to get a fresh edge. The big key here is to do maybe 2 light coats of paint. It’s not a wear surface, you just need color. If you go too heavy the paint will bridge the tape and you’ll end up having to recut the paint at the tape line to prevent pulling some of the painted surface when you remove the tape, and that won’t look as clean. As Dan says, very tedious. 1 Quote Link to comment Share on other sites More sharing options...
Denny Posted December 25, 2023 Author Share Posted December 25, 2023 thanks for the suggestions guys. I fooled around with the best caps I had which are driver quality only. didnt turnout to bad used the spray and wipe the high spots with a gas rag Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted December 26, 2023 Share Posted December 26, 2023 Very nice 👍 1 Quote Link to comment Share on other sites More sharing options...
Vaughn Posted December 26, 2023 Share Posted December 26, 2023 They look great. Quote Link to comment Share on other sites More sharing options...
