Window crank recommendations
black07ss
I'm very unhappy with the window cranks I purchased from a vendor at Carlisle They fit terrible on the spline. Recommendations on a quality crank is greatly appreciated.
The aftermarket do not fit well. Exactly what you described. The only other alternative is  NOS, which can be expensive, but in this case, worth it or a good used set.
Worst case scenario is that you could go down to the local pick-n-pull and get a set off of an old car.
Just about any G.M. crank will fit. G.M. liked consistency back then. ;)
