Guest Orangehat44 Posted May 28, 2009 Share Posted May 28, 2009 Hey guys. I feel silly but i was on my way over to the garage to change tranny and differentail fluid since i havnt done either in my 2 years of owning my monte. And went to look up what lubricants i needed to buy and realized there is different gear oils for standard rear ends or positraction rear ends. Since i never had to look this up and havnt done anything involving the drive line on my car i never deteremined exactly what rear end i have. Is there an easy way to determine which rear end i have. And is there a reccomendation for using one lube if not sure. Can i put posi lube in to play it safe? or do i have to make sure the right lube goes in the right diff. thanks Quote Link to comment Share on other sites More sharing options...
Ian Posted May 28, 2009 Share Posted May 28, 2009 Check this page http://www.firstgenmc.com/tech/rearaxledecoding.shtml Also a easy way to tell if it is a posi is to jack it up and turn a wheel, if the other side turns the same way it could be a posi, but if not it still could be a posi with bad clutches... The best way to tell is take the cover off... You would use the same oil, but for a posi you want to add the additive... Quote Link to comment Share on other sites More sharing options...
monte70car Posted May 28, 2009 Share Posted May 28, 2009 And what if both wheels don't turn then what you have? Quote Link to comment Share on other sites More sharing options...
ripleydale Posted May 28, 2009 Share Posted May 28, 2009 A problem. Usually both wheels turn, the same way for a posi, and opposite ways for a non posi. Quote Link to comment Share on other sites More sharing options...
stangeba Posted May 29, 2009 Share Posted May 29, 2009 Don't you have to remove the rear cover to drain the fluid anyway? I guess you could suck it out the fill hole but what fun would that be. As a word of caution, be sure you can remove the FILL plug before you drain everything out by removing the rear cover. If it's too rusted to budge, you will never be able to re-fill it! Good luck, Bruce Quote Link to comment Share on other sites More sharing options...
monte70car Posted May 29, 2009 Share Posted May 29, 2009 I think the reason why my don't turn like Ian said is the power trax unit is locked. Quote Link to comment Share on other sites More sharing options...
Ian Posted May 29, 2009 Share Posted May 29, 2009 Put the transmission in any gear except park Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted May 29, 2009 Share Posted May 29, 2009 the reason yours will not turn is that it is in park. a good posi will not turn in park Quote Link to comment Share on other sites More sharing options...
