monte70car Posted October 30, 2009 Share Posted October 30, 2009 Was wondering how much trans fuild we would need. The trans is a turbo 400 with a deep chrome pan and a exteral trans cooler which the trans is hooked to, the converter is dry. Quote Link to comment Share on other sites More sharing options...
neverdone71 Posted October 30, 2009 Share Posted October 30, 2009 Rob if I remember correctly,it's 10 to 12 quarts.Probably more with the deep pan & cooler. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 30, 2009 Share Posted October 30, 2009 Rob if I remember correctly,it's 10 to 12 quarts.Probably more with the deep pan & cooler. Â that's a good start Rob....you might want to start with about 8, let it warm up good and then add from there. It's easier to put it in than take it out... Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted October 30, 2009 Share Posted October 30, 2009 Jimmy, think with your dipstick! Yeah, I hate that commercial as well. Â Here is the best way. Fill the convertor with two quarts. It takes some time as the air will bubble out slowly. Pop the convertor in. Install the tranny. Fill the trans with five quarts then start it up for ten seconds. Add two more quarts. Start it up and run it through the gears. With the car running start adding whatever it takes to get the mark on the stick where it reads "full hot" Â A TH400 with a deep pan should hold right at 12.4 quarts of the red stuff. Â Andy Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted October 30, 2009 Share Posted October 30, 2009 Just fill to it's full.. Quote Link to comment Share on other sites More sharing options...
monte70car Posted October 31, 2009 Author Share Posted October 31, 2009 The thing is the trans is in the car and bolted up. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted October 31, 2009 Share Posted October 31, 2009 ACK!! that's a REALLLLY bad idea ert.. starting a trans with a dry converter can do a lot of damage.. Â it's sorta like firing up an engine for the first time w/o priming the oil system.. it's just not a good idea. Â fill the trans till the dipstick shows full. if it's a stock GM dipstick. .fill it almost to the bulge in the stick w/o the engine running.. fire it up.. and immediately shut it down again. hopefully it will be able to prime itself and suck the fluid down.. do that again, and then try to check the fluid with it running and see where you are at. Â Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted October 31, 2009 Share Posted October 31, 2009 It is in your best interest to pull it back out to fill the convertor. Like Timmay said, you should not do your tranny dry! Â Andy Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 1, 2009 Share Posted November 1, 2009 you should not do your tranny dry! Andy   ohhhh the places I could go with this.... but it IS a PG site :>  Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted November 1, 2009 Share Posted November 1, 2009 Timmay, you are fish. Now take the bait and run with it. Remember what my dad always told me. "A little lube never hurts" Â Andy Quote Link to comment Share on other sites More sharing options...
Chevyss Posted November 1, 2009 Share Posted November 1, 2009 Boys, Boys!! Now Now!! Behave Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted November 1, 2009 Share Posted November 1, 2009 or not..... Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 3, 2009 Share Posted November 3, 2009 Quote Link to comment Share on other sites More sharing options...
