Wibbs Posted January 11, 2010 Share Posted January 11, 2010 I just bought my 1971, needing a wiring repair to get it running. The wiring is complete, and car is running, but I have no reverse. Forward gears work fine. Fluid level is good, and fluid is cherry red.Linkage is adjusted. Any ideas anyone? Thanks in advance........ Mark Quote Link to comment Share on other sites More sharing options...
USMCBLB125 Posted January 11, 2010 Share Posted January 11, 2010 Depends on what you mean by no reverse. Does the transmission just slip when it's in reverse, or you cannot get reverse to engage at all? If you cannot get it to engage, I'd say something is still wrong with your linkage. If it's slipping time for a rebuild. Quote Link to comment Share on other sites More sharing options...
Wibbs Posted January 13, 2010 Author Share Posted January 13, 2010 Thanks for the input. It does not seem like it is slipping. Just nothing. I was thinking along the same lines with the linkage. I will look at it this weekend. It is probably moot anyway, as I have decided to put a new TCI trans in it this spring anyway. Mark Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted January 14, 2010 Share Posted January 14, 2010 Did the car sit for a while? You can try cycling between reverse & drive with the engine running. drive for 15 seconds, reverse for 15 seconds...give it a couple of minutes, it may unstick/clear Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 14, 2010 Share Posted January 14, 2010 slowly shift from park and see if it drops into reverse somewhere, the linkage may just need to be adjusted Quote Link to comment Share on other sites More sharing options...
kc8oye Posted January 14, 2010 Share Posted January 14, 2010 did you check the flud level with the engine _RUNNING_ ? warm engine up to normal temp... slowly shift the trans one gear at a time all theway down to low-1 and back up to park. with the engine still idling, (IN PARK!!) check the fluid level. no reverse is usually the first sign that you _REALLY_ low on fluid. Quote Link to comment Share on other sites More sharing options...
stangeba Posted January 14, 2010 Share Posted January 14, 2010 Tim, Very good explanation of the proper way to check automatic transmission fluid level. Not everyone knows or pays attention to these little things. If I may add one thing, make sure the vehicle is parked on a level surface. Bruce Quote Link to comment Share on other sites More sharing options...
Wibbs Posted January 16, 2010 Author Share Posted January 16, 2010 Thanks to all for your input. Car had been sitting idle for awhile before I bought it. I drained the trans, added new filter and fluid, now everything seems ok. Next step.........(sigh) bodywork.......... Quote Link to comment Share on other sites More sharing options...
kc8oye Posted January 16, 2010 Share Posted January 16, 2010 Good point Bruce.. and t.y as a quick reference... it's not good to run a trans dry... if you check the fluid level with the engine off.. GENERALLLLLY speaking with a factory style dipstick, the fluid will come up somewhere near the 'twist' in the dipstick.. where it's bowed out... it's not scientific.. but if you aren't well past the 'full' mark with the engine off, you are definately very low. it only takes being 1/2 qt. low to make a TH350 act goofy. Quote Link to comment Share on other sites More sharing options...
