DDay Posted February 27, 2010 Share Posted February 27, 2010 On the drivers side were the monte carlo emblem the chrome trim is poping off. When i pop it back it stays for a second and then comes off. How could I fix this? Would a dab ob caulk or somthing due the job or should I remove it and replace? Link to comment Share on other sites More sharing options...
overdrive Posted February 28, 2010 Share Posted February 28, 2010 I'd check the plastic clips. They are either damaged or the trim is deformed a little. Look closely and see if you can tell why it's not staying put. I'd think you could get some good used clips from someone here pretty cheap, if that's what you need. Dan Link to comment Share on other sites More sharing options...
bobsmc Posted February 28, 2010 Share Posted February 28, 2010 if you need trim i have a few sets of top trim that ive been selling off pieces from pm me if you need something and i probably have the clips too. bob Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 28, 2010 Share Posted February 28, 2010 if the trim got pulled off, the edges that hold it may have gotten bent out, you may be able to bend it back and snap it back on, I would try this first, it doesn't cost anything Link to comment Share on other sites More sharing options...
