AndyBill402 Posted August 16, 2010 Share Posted August 16, 2010 Has anyone removed the oil filter bypass on their car? I removed mine using a kit either from Summit or Jegs. It insures that 100% of the oil gets filtered and none get's bypassed. I use a K&N HP3002 oil filter to handle the extra pressure in the oil filter during cold startups. I would like to hear feedback from others because I don't have any perspective on doing this long term. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted August 17, 2010 Share Posted August 17, 2010 I remove the bypass on all my big and small blocks. Make sure you keep your oil changed. I like that all the oil gets filtered. You really don't need to buy the adapter. I just knock out the bypass and tap it and install a 1/4 pipe plug. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted August 25, 2010 Share Posted August 25, 2010 Sam runs his plugged to.. hopefully he'll chime in. Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted August 25, 2010 Share Posted August 25, 2010 I have the stock filter adapter tapped and pluged also, with a Melling high volume pump. I use a Fram PH25 (I think) filter. I have had no issues. Quote Link to comment Share on other sites More sharing options...
71monteme Posted August 25, 2010 Share Posted August 25, 2010 yup. tapped and plug mine, alos high volume pump, i use a mobil-1 oil filter for their high burst rating. no problem Quote Link to comment Share on other sites More sharing options...
