Shadow Gray SS Posted November 18, 2010 Share Posted November 18, 2010 I know I read on here about having to change the distributor gear sometimes but I can't find the thread. What is the story with that, I am gonna be switching to the MSD soon and want to be sure I don't skip anything. Also, the issue I am having with the car not starting appears to be a bad module on the HEI that's in there. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted November 18, 2010 Share Posted November 18, 2010 If you are running a cast cam you should be fine with the gear that comes on the distributor. If you have a GM roller cam motor you should run a melonized gear. If you are running a billet roller a bronze gear or a polymer gear. They say the polymer gears last longer than bronze but cost more. My billet cam was custom ground on a stick with a pressed on cast iron end #5 bearing and gear. No need for special distributor gear. Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted November 18, 2010 Share Posted November 18, 2010 What kind of cam exactly do you run? Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted November 18, 2010 Author Share Posted November 18, 2010 a custom grind Comp Cams hyd flat tappet, so I should be good Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted November 18, 2010 Author Share Posted November 18, 2010 This is the specs my engine guy used. I thought it was a custom grind, maybe not. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 18, 2010 Share Posted November 18, 2010 get an MSD #8360 that's the ProBillet Ready-to-run, it hooks up just like an HEI. power and tach, and two coil wires. since it's not coil-in-cap.. run it with a Blaster2 coil and you are ready to rock. If you want to use an MSD6 or similar, get the probillet that's not labeled "ready-to-run" it's about $100 cheaper, and REQUIRES an MSD box of some kind. (MSD 6, 6A, 6AL, 6AL-2, 7 etc) another option although pricey, is the E-curve like Ert uses. set your timing curve with dials and has a built in rev limiter. I'm not sure how this would work with an MSD box. this also eliminates the traditional vacuum advance can if appearance is an issue. Picture of my #8360 installed: http://home.comcast.net/~kc8oye/Engine/newvacline.jpg Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted November 18, 2010 Author Share Posted November 18, 2010 I went with the MSD small base style so the EFI can control the timing and I have the 6AL-2 and this coil. Quote Link to comment Share on other sites More sharing options...
monte70car Posted November 18, 2010 Share Posted November 18, 2010 Jake that's like the distributor in the Nomad. I know in the manual for the e-curve it shows a msd box being used and how its done. Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted November 18, 2010 Author Share Posted November 18, 2010 I actually even got instructions with my Holley EFI on those specific parts. Came with a special harness for it as well. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 18, 2010 Share Posted November 18, 2010 Sweet jake.. That's an even better setup then I suggested. I didn't think about you letting the EFI control the timing. that's the basic GM TBI ignition setup with that coil.. simple but reliable. I'm guessing the TPI engines might have used it too. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 18, 2010 Share Posted November 18, 2010 I know in the manual for the e-curve it shows a msd box being used and how its done. ahh that's cool ert. i figured it could be done. just wasn't sure about how. Quote Link to comment Share on other sites More sharing options...
DavidTX Posted November 18, 2010 Share Posted November 18, 2010 I wasn't sure about what was correct for my engine so I called MSD. They told me that their distributor comes with a melonized gear attached. Quote Link to comment Share on other sites More sharing options...
Andreas Posted November 18, 2010 Share Posted November 18, 2010 I wasn't sure about what was correct for my engine so I called MSD. They told me that their distributor comes with a melonized gear attached. Must be true, I got the same answer when I called them about my Pro-Billet distributor. So far, it works great with the roller cam... Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 19, 2010 Share Posted November 19, 2010 I have no idea what my MSD distributor has.... I bought it used.. Any ideas sam? Quote Link to comment Share on other sites More sharing options...
