71ss454 * (Larry) Posted December 5, 2010 Share Posted December 5, 2010 I am putting my motor and trans and it seems like the trans is mounted about a little less than a inch off center to the drivers side can someone confirm that is right . Thanks Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted December 5, 2010 Share Posted December 5, 2010 Larry, pretty common in my experience. Loosen the motor mount bolts and use a pry bar to straighten it out. Andy Quote Link to comment Share on other sites More sharing options...
overdrive Posted December 15, 2010 Share Posted December 15, 2010 Look closely at the motor mounts and see if they are made correctly. I had new ones from O'Reillys that were junk. The metal pieces weren't centered in the mold before the rubber was injected and the mounts had the motor and trans out of alignment with the frame. Dan Quote Link to comment Share on other sites More sharing options...
kc8oye Posted December 15, 2010 Share Posted December 15, 2010 i had the same problem once.. ultimately I replaced both engine mounts and the problem went away... Quote Link to comment Share on other sites More sharing options...
