ss4ever Posted January 10, 2011 Share Posted January 10, 2011 I have a 454 engine I am looking to build for my 72 and I have a couple questions. What headers fit good with a BBC in these cars? I am thinking full length coated headers. What intake setups will fit under a stock hood. I am thinking a raised dual plane design like the Edelbrock Performer RPM with a 750 Edelbrock carb on top. I currently have a 350 in my Monte and I plan on installing a 200-4R transmission in it but I already know that my stock 454 flexplate will not fit in the 200-4r, checked that out already. Any chance someone makes a 153 tooth flexplate ballanced for a 454? As for the 454 it will be .030 with a stock crank and rods, possibly forged pistons, non-stock camshaft(hopefully roller), rebuilt 781 heads, Edelbrock Performer RPM intake, Eddy 750 carb, headers, stock HEI distributor and electric fans. Nothing too fancy just big and noisey Thanks for all the head guys. Quote Link to comment Share on other sites More sharing options...
LuckyKenny Posted January 10, 2011 Share Posted January 10, 2011 Well....... really it's a 468 Quote Link to comment Share on other sites More sharing options...
Tims71 Posted January 10, 2011 Share Posted January 10, 2011 I have a 454 engine I am looking to build for my 72 and I have a couple questions. What headers fit good with a BBC in these cars? I am thinking full length coated headers. What intake setups will fit under a stock hood. I am thinking a raised dual plane design like the Edelbrock Performer RPM with a 750 Edelbrock carb on top. I currently have a 350 in my Monte and I plan on installing a 200-4R transmission in it but I already know that my stock 454 flexplate will not fit in the 200-4r, checked that out already. Any chance someone makes a 153 tooth flexplate ballanced for a 454? As for the 454 it will be .030 with a stock crank and rods, possibly forged pistons, non-stock camshaft(hopefully roller), rebuilt 781 heads, Edelbrock Performer RPM intake, Eddy 750 carb, headers, stock HEI distributor and electric fans. Nothing too fancy just big and noisey Thanks for all the head guys. I hope thats a typo or were you shooting for quote of the week Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted January 10, 2011 Share Posted January 10, 2011 I have a 454 engine I am looking to build for my 72 and I have a couple questions. What headers fit good with a BBC in these cars? I am thinking full length coated headers. Hooker Comps are a nice fit but 2" primaries will kill a little low end. What intake setups will fit under a stock hood. I am thinking a raised dual plane design like the Edelbrock Performer RPM with a 750 Edelbrock carb on top. I have a Victor Jr under my 71 hood with a nitrous plate under it and a Corvette drop base air cleaner fits just fine. I currently have a 350 in my Monte and I plan on installing a 200-4R transmission in it but I already know that my stock 454 flexplate will not fit in the 200-4r, checked that out already. Any chance someone makes a 153 tooth flexplate ballanced for a 454? A 14" external balanced flywheel will fit just fine. Just find a dual bolt pattern SFI flexy and you will be ok. As for the 454 it will be .030 with a stock crank and rods, possibly forged pistons, non-stock camshaft(hopefully roller), rebuilt 781 heads, Edelbrock Performer RPM intake, Eddy 750 carb, headers, stock HEI distributor and electric fans. Nothing too fancy just big and noisey Thanks for all the head guys. REALLY? Quote Link to comment Share on other sites More sharing options...
Heckeng Posted January 10, 2011 Share Posted January 10, 2011 Sounds like you have a great start there. It is possible your 454 has forged crank and rods too, be sure to ask your engine guy about them. You're going to like those heads too, it ought to be a torque monster. Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted January 10, 2011 Share Posted January 10, 2011 2 inch Hookers may be overkill on a fairly mild 454, but they fit reasonable well - there are several threads about it. I just did the driver's side on my 502 yesterday, and it requires moving the proportioning valve up and over, and I also have slight contact with the lower control arm mount, which I may have to dimple. I've heard the Hedman 3/4 length fit perfect, but they are only 1 5/8 I believe. With my 454, I ran a Holley Strip Dominator with an 800 dp, drop base air cleaner, and still had room for a 4 inch element (no underhood insulation). There should be plenty of room with a 3 inch element. Quote Link to comment Share on other sites More sharing options...
bigtankjones Posted January 10, 2011 Share Posted January 10, 2011 I installed a Gen V 454 into my '70 Monte. I used a Edelbrock Performer Intake with a Holly 750 carb, and 2" Hooker headers. I had to disconnect my steering shaft from the gearbox to get the left side header in. Still have about 2 to 3 " of clearance when I close my hood. Quote Link to comment Share on other sites More sharing options...
cudax Posted January 11, 2011 Share Posted January 11, 2011 I have a 454 engine I am looking to build for my 72 and I have a couple questions. What headers fit good with a BBC in these cars? I am thinking full length coated headers. What intake setups will fit under a stock hood. I am thinking a raised dual plane design like the Edelbrock Performer RPM with a 750 Edelbrock carb on top. I currently have a 350 in my Monte and I plan on installing a 200-4R transmission in it but I already know that my stock 454 flexplate will not fit in the 200-4r, checked that out already. Any chance someone makes a 153 tooth flexplate ballanced for a 454? As for the 454 it will be .030 with a stock crank and rods, possibly forged pistons, non-stock camshaft(hopefully roller), rebuilt 781 heads, Edelbrock Performer RPM intake, Eddy 750 carb, headers, stock HEI distributor and electric fans. Nothing too fancy just big and noisey Thanks for all the head guys. Man, I knew we had some friendly people here but I think that is going a little too far for me! Don't ask don't tell? Anyways, I run a 3" filter with a drop base on top of a 800 DP Holley with an Edelbrock RPM Air Gap with just enough clearence. Mike Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 11, 2011 Share Posted January 11, 2011 Well....... really it's a 468 no actually it'll be a 460, a 468 is a .060 over 454 Quote Link to comment Share on other sites More sharing options...
Heckeng Posted January 11, 2011 Share Posted January 11, 2011 HIIIIIIIIlarious! Quote Link to comment Share on other sites More sharing options...
ss4ever Posted January 11, 2011 Author Share Posted January 11, 2011 Woops sorry about the slip up guys, don't know where my mind was Good to know of the hood clearance. Right now my air cleaner is fairly close to the hood as it is with the 350, wasn't sure how it would be with the big block. I will start keeping my eyes open for a good used Performer RPM intake and some mid length headers. Quote Link to comment Share on other sites More sharing options...
