maddmann313 Posted June 14, 2011 Share Posted June 14, 2011 Would this be good to use in my stock 350/350 4bbl with stock gears? http://www.jegs.com/i/Comp-Cams/249/CL12-600-4/10002/-1?parentProductId= Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted June 15, 2011 Share Posted June 15, 2011 what gears Dillon? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 15, 2011 Share Posted June 15, 2011 it will have a very rough idle and poor vacuum at idle Quote Link to comment Share on other sites More sharing options...
robs70monte Posted June 15, 2011 Share Posted June 15, 2011 Go with something like the 268H or XE268 comp cams not to mild and not to wild well the xe is a bit more wild but there both street able cams Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted June 15, 2011 Share Posted June 15, 2011 It makes my head hurt to keep saying this over and over, but call your favorite cam manufactures tech line(cam help). Get an older hot rodder/racer on the line, as he/she asks you all the questions about your setup answer truthfully, and he/she will give you a cam kit part number that will be right for your application even if it means they have to grind one just for you. More times than not an off the shelf piece is in the ball park at best and not spot on for your car. Believe who you want, but that is truth. Quote Link to comment Share on other sites More sharing options...
