TrunkMatt Posted September 8, 2011 Share Posted September 8, 2011 So, my mechanic is recommending the following Cam spec's for the 383 I am having built: Hydraulic Cam SAE Duration: INT 288 EXH 298 Valve Lift: INT .444 EXH .466 CAM Lift: INT .296 EXH .311 Break it down for me what to expect. I said I needed something street-able, as I am not going to race this (maybe once in a while at track night for fun). I want something that provides enough vacuum to not have to run a canister, and something that would keep me from needing a new stall converter on my TH350... yet gives me the torque / grunt of my 383 with a nice lope. Good choice of Cam?? Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted September 8, 2011 Share Posted September 8, 2011 Be nice to see the .050 duration Quote Link to comment Share on other sites More sharing options...
TrunkMatt Posted September 8, 2011 Author Share Posted September 8, 2011 .050 DUR INT 214 EXH 224 Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted September 9, 2011 Share Posted September 9, 2011 Nice mild cam Quote Link to comment Share on other sites More sharing options...
TrunkMatt Posted September 9, 2011 Author Share Posted September 9, 2011 So it'll fit my needs you think? Have a bit of a lope with decent low end torque & HP... but not cause me to do a million upgrades to support it? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted September 9, 2011 Share Posted September 9, 2011 what's the intake centerline and lobe seperation angle? Quote Link to comment Share on other sites More sharing options...
AL M Posted September 9, 2011 Share Posted September 9, 2011 too small. Quote Link to comment Share on other sites More sharing options...
TrunkMatt Posted September 9, 2011 Author Share Posted September 9, 2011 Here is everything on the spec sheet: .050 TIMING ---------- BTC: 0 ABC: 34 BBC: 49 ATC: -5 .050 DUR. ----------- INT: 214 EXH. 224 LASH HOT ----------- INT. HYD EXH. HYD LOBE CTRS. ----------- INT 107 EXH 117 VALVE LIFT ----------- INT .444 EXH .466 CAM LIFT ----------- INT .296 EXH .311 SAE TIMING ----------- BTC 32 ABC 76 BBC 81 ATC 37 SAE DUR ----------- INT 288 EXH 298 Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted September 9, 2011 Share Posted September 9, 2011 Too small. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted September 10, 2011 Share Posted September 10, 2011 From your initial statement, the cam sounds like what you are looking for. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted September 10, 2011 Share Posted September 10, 2011 I agree with Mike, those specs are close to the ole L79 GM cam which is a good runner with a slight lope.... Quote Link to comment Share on other sites More sharing options...
TrunkMatt Posted September 11, 2011 Author Share Posted September 11, 2011 Great comments everyone - thanks for your feedback! Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted September 13, 2011 Share Posted September 13, 2011 For the hundredth time call your favorite cam manufacture and get the tech help you need to spec out the proper cam for your application. Make sure the person you are taliking to is at least 30 years old and has is a hot rodder/racer for a long time. There are very few off the shelf cams that are a perfect fit for a given application. If your manufacture doesn't ask you all the details about your car and it's driveline, hang up and call one who does. Quote Link to comment Share on other sites More sharing options...
TrunkMatt Posted September 13, 2011 Author Share Posted September 13, 2011 Precisely why I am having my Mechanic and the guys at PER (http://www.portlandenginerebuilders.com/) handle this for me. I gave them the information I originally wrote on my intended uses and scenarios --- and they provided me the spec sheet I posted. It is a custom cut cam... however, to double-check what I am getting -- I am just curious on everyone else's thoughts on the provided spec. Quote Link to comment Share on other sites More sharing options...
Mr70Monte Posted September 14, 2011 Share Posted September 14, 2011 its probably one of these 2 cams, http://www.summitracing.com/parts/LUN-01003/ or http://www.summitracing.com/parts/CRO-00904/ both have your same specs. looks to be a decent cam. Quote Link to comment Share on other sites More sharing options...
