clint w Posted February 26, 2012 Share Posted February 26, 2012 thinking about getting some moog el camino rear coil springs (part# cc507) and was wondering what shocks you were running with them? do not want air shocks thanks clint Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted February 27, 2012 Share Posted February 27, 2012 can you explain why you don't want airshocks? Quote Link to comment Share on other sites More sharing options...
clint w Posted February 27, 2012 Author Share Posted February 27, 2012 my only dealings with them were on friends cars in the '80s and they leaked,cheap plactic lines that had to be mounted in the trunk.maybe they have become better quality now?? Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted February 27, 2012 Share Posted February 27, 2012 still cheap plastic lines, but you can upgrade to rubber if you want.. mine run behind the flip license plate. You can literally fill it with a bike pum IF you wanted lol. Â I got my set on summit for 60-something dollars. Â -Mark Quote Link to comment Share on other sites More sharing options...
clint w Posted February 27, 2012 Author Share Posted February 27, 2012 http://www.ebay.com/itm/390362757473?item=390362757473&viewitem=&vxp=mtr i'm assuming this is for both springs? Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted February 27, 2012 Share Posted February 27, 2012 usually a set of 4 or 2, wouldnt hurt to shoot them an email Quote Link to comment Share on other sites More sharing options...
monte70car Posted February 27, 2012 Share Posted February 27, 2012 Springs are usual sold in pairs, just like air shocks. You could always hard line the air shock like gm did for the el camino their is a place on the net that carries the metal line and block the screw into at the rear Quote Link to comment Share on other sites More sharing options...
clint w Posted February 28, 2012 Author Share Posted February 28, 2012  hope the pic shows up.i have the original springs that look like they have sagged. i really don't want a "jacked up" look. just want the new wheel/tire combo to work. i bought some 15x8 rally wheels with 4.5" backspace. i plan on running 275-60-15 tires. i'm thinking i can get away with some new stock springs moog part#cc501. if anyone sees a problem with this setup please let me know  thanks for your help edit.. can't get the pic to show up but its in my new members post Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted February 28, 2012 Share Posted February 28, 2012 I'm using Moog CC501's. I also have 275/60-15 Radial TAs mounted on 15x8 rallys with 5" backspacing on the rear. If you want to use 4 1/2" backspacing, you may need to trim some of the rear wheel lip. Quote Link to comment Share on other sites More sharing options...
clint w Posted February 28, 2012 Author Share Posted February 28, 2012 I'm using Moog CC501's. I also have 275/60-15 Radial TAs mounted on 15x8 rallys with 5" backspacing on the rear. If you want to use 4 1/2" backspacing, you may need to trim some of the rear wheel lip. Â i looked on ebay and was looking the best deal for the springs. some cc501 were not compatible with my car. isn't that the part# and any with that part# work ? Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted February 28, 2012 Share Posted February 28, 2012 Yes, CC501 is the correct part number for the variable rate springs. I wouldn't rely on eBay for compatibility information. Quote Link to comment Share on other sites More sharing options...
Ian Posted February 28, 2012 Share Posted February 28, 2012 The best price I found on CC501's was Amazon Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted February 28, 2012 Share Posted February 28, 2012 CC501 on my car got them off ebay for about 75 or 80 bucks with shipping. Work perfectly. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted February 29, 2012 Share Posted February 29, 2012 I run the softest spring that NAPA lists for a monte and fit 275/60s without an issue. I like a softer rear suspension for my goals. the cc501s should be fine Quote Link to comment Share on other sites More sharing options...
