maddmann313 Posted May 18, 2012 Share Posted May 18, 2012 What would cause my 1972 monte Carlo to have only 20-40 psi of oil pressure? I checked the oil and it's fine... It's a 350 sb Quote Link to comment Share on other sites More sharing options...
Heckeng Posted May 18, 2012 Share Posted May 18, 2012 Bad pressure spring in the oil pump, gas in the oil, plugged oil pump screen. I'm sure there will be some other people with more ideas too. Quote Link to comment Share on other sites More sharing options...
gprimm Posted May 18, 2012 Share Posted May 18, 2012 Generally speaking you shouldest have 10psi for each 1,000 of RPM. Quote Link to comment Share on other sites More sharing options...
gprimm Posted May 18, 2012 Share Posted May 18, 2012 As the oil heats up it hers thinner and will have a little less. As long as you don't hear lifters you should be fine. Is it an untouched and stock oil pump? Quote Link to comment Share on other sites More sharing options...
maddmann313 Posted May 18, 2012 Author Share Posted May 18, 2012 Yes it is the stick oil pump. Quote Link to comment Share on other sites More sharing options...
gprimm Posted May 18, 2012 Share Posted May 18, 2012 If you have 10psi for each 1000 rpm you are fine. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted May 18, 2012 Share Posted May 18, 2012 Yes it is the stick oil pump. at what speeds? Idle...cruise....full throttle....? Quote Link to comment Share on other sites More sharing options...
FASTSS454 Posted May 18, 2012 Share Posted May 18, 2012 If you have 10psi for each 1000 rpm you are fine. X2 Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted May 18, 2012 Share Posted May 18, 2012 How many miles are on it? If it is stock original it is fine at 40 psi. If you are racing not so much, like everybody states 10 psi per 1000. Mine idles at 20 and goes to about 75 at 6900 but it is a big block. Same rules seem to apply. If you look in some of the old Chilton books they state 40 as max. Quote Link to comment Share on other sites More sharing options...
72MC Posted May 19, 2012 Share Posted May 19, 2012 I don't think you have a problem. My fairly new rebuild is like Mikes. On start up, I get 75-77 psi. After running for a while, at idle, I show 27-30 psi. Upon accelation, the psi climbs to 65-70 psi. Highway cruising, I show about 65 psi. I run a high volume pump, not a high pressure pump. My stock to mild 350 with a stock pump prior to the 383 ran in the ranges you have and I had no oiling issues. - Dave Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted May 19, 2012 Share Posted May 19, 2012 Quote Link to comment Share on other sites More sharing options...
