gprimm Posted June 6, 2012 Share Posted June 6, 2012 I am ready to put the engine & trans back in the Monte so I can drive this bad boy. On this redo, when I added Edelbrock RPM heads, I started with stock rockers, went to roller tip and now full Procomp roller rockers. Question: do the roller rockers "tick" when running? That's one reason I took the roller tips off because on my sons engine they made noise and the engine builder told us before he assembled the engine that they'd make noise, and they did. If they tick too loud, I don't know that I am interested in running them. If not, I will. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted June 6, 2012 Share Posted June 6, 2012 Solid lifters make some noise because of the lash but hyd. should be pretty quiet as far as I know. Quote Link to comment Share on other sites More sharing options...
gprimm Posted June 7, 2012 Author Share Posted June 7, 2012 Yes, I know of the solid lifters noise, was wondering if the aluminum full roller rockers make a noise? I assume no. The roller tip steel rockers did. Quote Link to comment Share on other sites More sharing options...
71monteme Posted June 7, 2012 Share Posted June 7, 2012 what cam are you running? as stated solid lifter/ cam will make noise, hydro- cam should not, if you adjust them correctly, should not make any noise unless the rockers themselves are bad. thanh Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted June 8, 2012 Share Posted June 8, 2012 some roller rockers will make a little noise, especially aluminum ones. Nothing like some soild roller cams but some ticking, a lot depends on the lifters used and the bleed down rates too. If it's mainly a street motor and you are committed to a roller rocker I would use some good steel ones, they will take more heat cycles and are a little less prone to breakage... Quote Link to comment Share on other sites More sharing options...
Mom's Car Posted June 8, 2012 Share Posted June 8, 2012 I find that Rockin Rollers tend to be very loud. Don't they know how to play music more quietly? Quote Link to comment Share on other sites More sharing options...
gprimm Posted June 9, 2012 Author Share Posted June 9, 2012 Dave, I am using them because I got a great price. I initially had roller tip and before that stock. They have about 3,000 miles on them and got the rockers and the nuts for $45. Still debating. Mom's car: Quote Link to comment Share on other sites More sharing options...
jstadter Posted October 11, 2012 Share Posted October 11, 2012 Sorry to resurect an old thread... George, did you have any issues with fitting either the roller tip rockers or the roller rockers under the stock valve covers? Quote Link to comment Share on other sites More sharing options...
dbreese Posted October 11, 2012 Share Posted October 11, 2012 I ran comp magnum roller tip rockers under stock v/c's with no issues. http://www.summitracing.com/parts/CCA-1411-16/ David Quote Link to comment Share on other sites More sharing options...
jstadter Posted October 12, 2012 Share Posted October 12, 2012 Good deal - thanks, David. Quote Link to comment Share on other sites More sharing options...
gprimm Posted October 13, 2012 Author Share Posted October 13, 2012 The roller tips worked with the stock valve covers. When I switched to the full rollers I had to use taller covers. I got mine from Skip White on Ebay, the "semi tall" ones for $14, chrome and they work great. I just bought a second set and am going to paint those Chevy orange. I like the contrast of the orange covers on the aluminum heads. Quote Link to comment Share on other sites More sharing options...
jstadter Posted October 13, 2012 Share Posted October 13, 2012 Thanks for the info George. At this point I'm inclined to start off by trying the roller tips. Quote Link to comment Share on other sites More sharing options...
