93Octane Posted June 23, 2012 Share Posted June 23, 2012 Does anyone have a general idea as to why my pass. side blinker or brake lights wont work? changed brake switch, bulbs, checked ground, turn signal switch and wires aren't pinched. The driver side works great. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 23, 2012 Share Posted June 23, 2012 you need to test with a volt meter or test light and find out if you have power to the socket and work back from there if power is at socket, it's a ground, or bulb no power, check at plug in harness in the trunk, no power there, go to plug under the dash... Quote Link to comment Share on other sites More sharing options...
bigtankjones Posted June 23, 2012 Share Posted June 23, 2012 If you have to replace the the socket. Watch out cause there are some cheap ones out there were the bulbs fit loosely and wont get a good connection to the bulb. I had to buy a couple different ones to get a good one. Quote Link to comment Share on other sites More sharing options...
93Octane Posted June 24, 2012 Author Share Posted June 24, 2012 thnx guys. I found a connector with 4 wires. Green, White Brown and yellow. brown was spliced to tail light brown and white was ground to trunk. have pics but dont know how to upload Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 24, 2012 Share Posted June 24, 2012 green will be the pass brake/turn wire Quote Link to comment Share on other sites More sharing options...
93Octane Posted July 10, 2012 Author Share Posted July 10, 2012 does it go anywhere? Do I need It? http://members.webs.com/MembersB/editApp...lbumid=13642730 Quote Link to comment Share on other sites More sharing options...
montefrazer Posted July 12, 2012 Share Posted July 12, 2012 Your link needs a log in so can't look at the pictures. Just a thought. If it is a non factory splice, it could be trailer wireing. Did the car have a hitch? Quote Link to comment Share on other sites More sharing options...
93Octane Posted July 14, 2012 Author Share Posted July 14, 2012 i didn't check the mistake sorry. http://93octanemontekid.webs.com/ no trailer Quote Link to comment Share on other sites More sharing options...
