71 MONTE 4 YA Posted September 26, 2012 Share Posted September 26, 2012 Is it necessary to change them when doing a cam? Quote Link to comment Share on other sites More sharing options...
wallaby Posted September 27, 2012 Share Posted September 27, 2012 Nope. They usually last the life of the engine. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted September 28, 2012 Share Posted September 28, 2012 buy if you see copper color, they need to be replaced Quote Link to comment Share on other sites More sharing options...
71 MONTE 4 YA Posted September 28, 2012 Author Share Posted September 28, 2012 Nope. They usually last the life of the engine. Originally Posted By: Sam (Bones) buy if you see copper color, they need to be replaced Thanks guys. I was going to let this one company do my engine work and they were saying that I need to change pushrods, cam bearings, deck the heads, and I was totally lost Quote Link to comment Share on other sites More sharing options...
dbreese Posted September 28, 2012 Share Posted September 28, 2012 Wow deck the heads for a cam swap. I don't think so. New lifters with a new cam is a must. I would get new pushrods as they are not that expensive. How are your valve springs and will they work with the new cam? Just food for thought. David Quote Link to comment Share on other sites More sharing options...
71 MONTE 4 YA Posted September 28, 2012 Author Share Posted September 28, 2012 Wow deck the heads for a cam swap. I don't think so. New lifters with a new cam is a must. I would get new pushrods as they are not that expensive. How are your valve springs and will they work with the new cam? Just food for thought. David I got new valve springs that the cam calls for. Everything that I got is recommended Comp Cam products. Springs, Lifters and I got some Scorpion full Roller Rockers. I will get some Comp Cam Push rods, Quote Link to comment Share on other sites More sharing options...
dbreese Posted September 28, 2012 Share Posted September 28, 2012 Sounds like you are good to go Rodney!!! What are the spec's on the cam? David Quote Link to comment Share on other sites More sharing options...
71 MONTE 4 YA Posted October 1, 2012 Author Share Posted October 1, 2012 Sounds like you are good to go Rodney!!! What are the spec's on the cam? David Hey David here are the CAM SPECS Quote Link to comment Share on other sites More sharing options...
FASTSS454 Posted October 1, 2012 Share Posted October 1, 2012 I would call COMP and ask the techie guy how much vacumn you should expect. If you get to low the power brakes will suffer. Quote Link to comment Share on other sites More sharing options...
dbreese Posted October 1, 2012 Share Posted October 1, 2012 Nice Rodney!!! That thing will sound nasty. You will turn some heads for sure. David Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 2, 2012 Share Posted October 2, 2012 that thumper has more duration than the one I put in my 454, I only pull 9-10" of vacuum at 850 rpm Quote Link to comment Share on other sites More sharing options...
71 MONTE 4 YA Posted October 2, 2012 Author Share Posted October 2, 2012 that thumper has more duration than the one I put in my 454, I only pull 9-10" of vacuum at 850 rpm Am I going to need a vacuum Pump? Also am I going to have a problem with the Compression Ratio? The cam needs 9:1 Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted October 2, 2012 Share Posted October 2, 2012 That is a pretty lumpy cam. It will probably be fairly soft on the bottom end. What rear gear are you running. If you have not purchased the cam I might consider a little smaller thumper cam. Quote Link to comment Share on other sites More sharing options...
71 MONTE 4 YA Posted October 2, 2012 Author Share Posted October 2, 2012 That is a pretty lumpy cam. It will probably be fairly soft on the bottom end. What rear gear are you running. If you have not purchased the cam I might consider a little smaller thumper cam. Mike I have everything already. I will be running a 3000 stall and 3:42 gears with 255/60/15 BFG's out back. Are you saying there will be no low end torque? Quote Link to comment Share on other sites More sharing options...
wallaby Posted October 3, 2012 Share Posted October 3, 2012 Well, you'll have some, but the more cam you put in, the more that bottom end torque will suffer. The idea of the bigger cam is to move the power band upward to perform better at higher speeds. Once the speed builds, it will pull like gangbusters, and that 3000 stall converter will give you a head start so slow speed power isn't as important. The gasoline engine has a useable power band of about 3000 rpm. You can get more, but it starts falling off. You just need to figure out which 3000 rpm you want to use: idle to 3000, 2000 to 5000, etc. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted October 3, 2012 Share Posted October 3, 2012 The stall and gears will be a help Quote Link to comment Share on other sites More sharing options...
