Will Posted November 23, 2012 Share Posted November 23, 2012 Im replacing the floor pans in my 71 and I was thinking while I was at it I could extend the rear wells into the trunk a bit to get me a lil extra width back there rubber wise. Nothing extreme. Maybe 6 inches or so would be enough room. My question is how wide can I go before I need to be concerned with snapping an axle or modifying the suspension. Thanks Will Quote Link to comment Share on other sites More sharing options...
Ian Posted November 23, 2012 Share Posted November 23, 2012 If I remember right the frame and the inner fender are in the same place, so just opening up the inner fender will not gain you much. Quote Link to comment Share on other sites More sharing options...
monte70car Posted November 24, 2012 Share Posted November 24, 2012 As Ian stated you would have to more the frame to get those extra 6" of width for the tire. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 24, 2012 Share Posted November 24, 2012 the wheel house and the frame are almost parallel, without doing the frame you might gain a inch or so....tops! Quote Link to comment Share on other sites More sharing options...
502ci Posted November 24, 2012 Share Posted November 24, 2012 As said above you won't gain much...I'll go one step further and say you won't gain a fraction of an inch without altering the frame. Using a mallet you can tap the stock wheel housing over a tiny bit and get the tire within a 1/4" to 3/8" like I did in the past. Here's a photo of how close you can get it. The gap in the picture is the tire to the frame. Quote Link to comment Share on other sites More sharing options...
Will Posted November 24, 2012 Author Share Posted November 24, 2012 Note to self. Not gonna happen, haha. Thanks for the info guys Quote Link to comment Share on other sites More sharing options...
