badddoin Posted August 26, 2013 Share Posted August 26, 2013 So I was cleaning my engine compartment when I figured it'd be easier to clean these frame rails if those pesky control arms weren't in the way. So I ordered some bushings and ball joints and off they came. This is a pic of my upper control arm pivot shafts. I did one of these montes 25 years ago, and I'm thinking both shafts were the same. Obviously, the passenger side shaft has found its way in and out of the blast cabinet. The drivers side is threaded on the inside. Is this right? Thanks. Quote Link to comment Share on other sites More sharing options...
MCfan Posted August 26, 2013 Share Posted August 26, 2013 Both sides were/are the same on my '70s, Tommy. They both look more like your driver's (unblasted) side. Not sure where the other one came from but it obviously works as long as the bolt holes and bearing surfaces are in the correct locations. Whether you put a bolt or a nut on each end is probably immaterial but it may look a bit odd if they are different from each other. Quote Link to comment Share on other sites More sharing options...
cudax Posted August 26, 2013 Share Posted August 26, 2013 Both of mine are the same on my 70 and are exactly like your drivers side, threaded inside. Mike Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 26, 2013 Share Posted August 26, 2013 those are updated newer style, they have a large nut to retain the bushing instead of the 5/16" bolt you can't buy the original style anymore Quote Link to comment Share on other sites More sharing options...
badddoin Posted August 26, 2013 Author Share Posted August 26, 2013 Thanks everybody for the input. I guess I'll put it back together the way it was, if Iever get it cleaned up. I've had this car over two years, and I've spent more time in the engine compartment than the drivers seat. The first I noticed it was when I went to take it apart, so apparently it doesn't bother me too much. Quote Link to comment Share on other sites More sharing options...
footballubet Posted August 26, 2013 Share Posted August 26, 2013 My 71 had the same as your passenger side and they were original. I know some of the earlier Chevelles had the bolt in the end. Maybe just using up old stock? Quote Link to comment Share on other sites More sharing options...
