Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Replacement axles
  • Please log in to reply
9 replies to this topic
#1 MeanMonte
MeanMonte
    Bronze Member
  • Members
  • 642 posts
  • LocationFairborn, OH USA
  • Occupation:Master Auto Technician
Posted 11 January 2007 - 05:06 PM
Ok im looking into replacing my axles with aftermarket ones to gain reliability on the strip. I know there are a few brands just thought i would ask if anyone has use or recomends certain ones over others... Thanks Eli
1970 Monte 385sbc Turbo!
Best Time: 11.02 at 113mph
http://www.cardomain.com/ride/684754
2005 GTO
2007 GSXR 750
#2 Heckeng
Heckeng
    Scott
  • Members
  • 3,155 posts
  • LocationColumbia MO
  • Legal Name:Scott Heck
  • Occupation:Engineer/Real Estate
Posted 11 January 2007 - 05:34 PM
I can't really compare different brands, but I installed Moser Axles, and they were quite an improvement at least size wise. They haven't broken yet either, so I guess that's good. The axle on the left is the stock one I pulled out, the one of the right is obviously the new Moser. you can see how the stock one necks down where the moser stays thick. I measured and there were 3/16" difference in diameter at the weak point on the stock axle!!! eek eek Hope that is helpful!
Scott
Posted Image
502ci, AFR 265's, Demon 750, Air gap intake, Straub custom cam, TH350, 3800 Edge converter, 3.55 12 bolt.
#3 502ci
502ci
    MODERATOR in the 11's
  • Moderators
  • 15,371 posts
  • LocationRichfield, Ohio
  • Legal Name:Bill
  • Occupation:Union Electrician / Local 38/Commercial, Industrial
Posted 11 January 2007 - 05:46 PM
I purchased a set of Moser C-clip axles and new axle bearings. The axles are like 30% stronger than stock and you can see where it comes from as the shaft does not taper. The bearings also were huge compared to the factory ones I removed.
I found out fairly recently we have a FGMCC member (Monzaz)that sells axles and related rearend parts and he only lives a few miles from me. He lists parts in the for sale section from time to time. Here's his profile... Monzaz
Bill
MolĂ´n Labe
11.80's at 114 mph, 0-60 in 3.34 sec.____
Click here to see my never ending project
__________Click here to hear it__________
#4 Sam (Bones)
Sam (Bones)
    FGMCC Treasurer monteholic moderator
  • Administrators
  • 17,782 posts
  • LocationOrtonville,Mi
  • Legal Name:monteholic
  • Occupation:Aviation Ground Equipment & Support Technician
Posted 11 January 2007 - 05:51 PM
I also used mosher axles w/ c-clip eliminators, had to, w/ slicks and the power I was making, it was good piece of mind wink
Sam
70 & 71 montes
#5 dbreese
dbreese
    Gold Member
  • Members
  • 2,367 posts
  • Locationga
  • Occupation:Law Enforcement (retired)
Posted 12 January 2007 - 05:09 PM
I have a set of Moser c-clip axles and they are substantialy thicker than the stock ones. No problems. Yukon and Strange also make good axles at reasonable price.
David
1972 Monte Carlo
Gulf Green.
Family owned since new.
414 s/b
4.30 gear
th350
11.28 @ 119.86 02/01/2015
ad390391-5036-4b2c-81a7-e0ed49d7c959_zps[/URL]
Hot Rod Drag Week finisher 07',08',09' and 13'
#6 mc71454
mc71454
    Brass Member
  • Members
  • 295 posts
  • LocationAlbany NY
  • Occupation:Civil/Environmental Engineer
Posted 26 January 2007 - 08:33 PM
I personally only use Mark Williams components.
I have never seen or heard of breakage or spline twisting with Mark Williams. They make a Masterline series good to 9.90's for $320 a set. Ran 30 spline axles in my Monte until the end of 2006. They have 900+ passes on them from 12's to low 10's.
I just went to 35 spline setup since I plan to put it into the 9's.
The 30 splines are going into my chevelle this winter.
Tom Baird - '71 Monte - NA, 10.310 @ 129.86 mph, 3950 pounds, 3.73 gears, pump gas driver
'70 Chevelle SS 454, 12.30's
'87 Buick Turbo T Limited, Stock
'87 Monte SS Aerocoupe, Stock
'07 Toyota Tundra 4WD, mods
#7 HarrisQ
HarrisQ
    Brass Member
  • Members
  • 260 posts
  • LocationSalisbury, Md
  • Occupation:Police Officer (RETIRED)
Posted 27 January 2007 - 06:08 AM
I have never used anything but Moser but I'm sure all the other companies are just as good.
#8 680HPStroker
680HPStroker
    Silver Member
  • Members
  • 1,538 posts
  • LocationSuffolk, Virginia
  • Occupation:Engineering Technician
Posted 29 January 2007 - 06:53 AM
I echo what mc71454 said about Mark Williams axles. Everything they make is for hard core racing and even the Masterline parts are as strong as other companies top of the line pieces are for less money.
BB
No subsitute for cubic inches!!
#9 Guest__*
Guest__*
  • Guests
Posted 31 January 2007 - 03:19 PM
Has anyone used these axle kits from summit. Alloy Usa kit includes everything for 209.00
http://store.summitr...15&autoview=sku
Seems like a pretty good deal, I was thinking of getting them but wanted to see what you guys think ???
#10 Ian
Ian
    Webmaster
  • Administrators
  • 7,039 posts
  • LocationAustin, AR
  • Legal Name:Ian Novinger
  • Occupation:Truck Mechanic
Posted 03 February 2007 - 11:34 AM
Yep I used the USA axles when I was fighting the vibration issue. They came with everything including the bearings. Fit was right on and they are thicker than the stock ones like the ones above from Moser. I think for the money they were a good deal. I am not going to be racing the car, so they should be fine.
Ian
-- Ian
"Experience is a hard teacher because she gives the test first, the lesson afterwords."
"Pick battles big enough to matter, small enough to win."
Home Page
Message Forum
Members' Montes|Meet Photos
