Body bolt & bushing help??????
hey guys for those of you that have replaced body bushings on your monte....off all the bolts that came out..i have 2 that are longer than the rest..where do these 2 bolts go..im thinkin they go in the back corners..jus tryin to confirm that before I put the body back on the frame
actually those bolts werent from the core support as i replaced those bushings before I even started takin the body off..the 2 longer bolts i had were actually the 2 in the rear corners under the trunk..western mees..hopefully since all i need now is a windhsield and a brake booster & master cyl and to decide if imma do the ac delete plate or not...decisions decisions!!!
