Sign in to follow this
smokinquack
HEI timing
I put a new HEI distributor in my 70  SS454. What do I set the timing at? Do I disconnect the vacuum line?  I ran the required wire to IGN spade on circuit breaker, What else do I need to know.
Share this post
I would start with the base timing for the motor. The HEI will provide a better spark to the plugs. I open my plugs to a wider gap similar to what the motors called for when the HEI came in.
Share this post
X2 to what monte70car said. I would also add 2-4 degrees advance if it is a stock engine. The factory was a little conservative back in the day. Lol
Share this post
With SB 350 and my HEI I gap the plugs at .045 and set my timing at 12 degrees. I also have the vacuum line hooked up.
Share this post
as stated,starting at around 12 degrees advance  sounds good - watch for pinging or run ,on make sure  your not running too lean then if you have an adjustable advance you can play around with that as well..not surprised and tend to agree the 6 to 8     factory stuff was too conservative...
Share this post
Spring has sprung here so I'm able to get the car out of the garage.  It runs but I dont have it dialed in. Once I get it idled down, (I think the Quadrajet still needs some tweeking) My timing light shows like 30 degrees advanced with the vacuum disconnected. hook the vacuum up and it dies. Ive rotated the distributor back and forth but cant seem to find where its suppose to be at.  My timing light fires sporadically so maybe its bad, Any thoughts?
Share this post
