BobRob Posted August 13, 2020 Share Posted August 13, 2020 1971 with a 350..... Does anyone have a source for the subject part? The guy I bought the car from put a rubber fuel line from the barbed fitting on the booster down to a fitting on the back of the intake. I'm replacing the 650 DP with a QJ and would like to get the correct PB booster line in there. Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted August 13, 2020 Share Posted August 13, 2020 https://www.opgi.com/fittings-hoses/lines/brake-vacuum-line-steel-power-brake/line-power-brake-1971-74-checmc-big-block-steel-ins7122.html Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 13, 2020 Share Posted August 13, 2020 Opgi like Paul posted, the parts place, inline tube, ground up, ausleys Chevelle, etc. Are a few others. Quote Link to comment Share on other sites More sharing options...
Dtret Posted August 13, 2020 Share Posted August 13, 2020 That may or may not be the correct the discription states big block. Quote Link to comment Share on other sites More sharing options...
BobRob Posted August 13, 2020 Author Share Posted August 13, 2020 23 minutes ago, Paul Bell said: https://www.opgi.com/fittings-hoses/lines/brake-vacuum-line-steel-power-brake/line-power-brake-1971-74-checmc-big-block-steel-ins7122.html Thanks, yeah I've seen them for a big block. Who knows, maybe it would be close enough.. I'm gonna keep looking. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 14, 2020 Share Posted August 14, 2020 I'm sure Paul was using the link for a description. You have to look around the website for the correct application. Quote Link to comment Share on other sites More sharing options...
BobRob Posted August 14, 2020 Author Share Posted August 14, 2020 From my searching and an inquiry to OPGI that has gone unanswered, there doesn't appear to be one for the SBC, only th BBC. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted August 14, 2020 Share Posted August 14, 2020 The parts catalog does only show the pipe for the big block. I do remember when I worked at a dealer we used fuel line for small blocks. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted August 15, 2020 Share Posted August 15, 2020 I finally found all the booster vacuum tubes that could have come on our cars: https://www.classicchevy.com/catalogsearch/result/?&q=Power Brake Booster Vacuum Supply Tube 1 Quote Link to comment Share on other sites More sharing options...
BobRob Posted August 19, 2020 Author Share Posted August 19, 2020 On 8/15/2020 at 10:33 AM, Paul Bell said: I finally found all the booster vacuum tubes that could have come on our cars: https://www.classicchevy.com/catalogsearch/result/?&q=Power Brake Booster Vacuum Supply Tube Great, thank you! I bookmarked the site and will have to peruse it later tonight. Quote Link to comment Share on other sites More sharing options...
