rsorg Posted March 1, 2021 Share Posted March 1, 2021 i noticed lately that i have to slam my drivers door to close all the way, could it be the door latch, door strike pin, or the door pins themselves ,thanks roger Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 1, 2021 Share Posted March 1, 2021 Maybe caused by door sag due to worn hinge pins in the hinges. Open the door and grab it on the latch side and lift to see if there is any up and down play in the hinges. Also, as you close the door slowly, when the latch will engage the latch pin in the door jamb see if the door starts to lift as it engages the latch pin. Both of these are indications of worn hinge pins. rob 1 Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted March 5, 2021 Share Posted March 5, 2021 Highly recommend get the door spring tool removal as it was a breeze for me to replace the pins and bushings! 1 Quote Link to comment Share on other sites More sharing options...
rsorg Posted March 5, 2021 Author Share Posted March 5, 2021 hi, where can i get the spring tool ,pins and bushings ,thanks roger Quote Link to comment Share on other sites More sharing options...
jft69z Posted March 5, 2021 Share Posted March 5, 2021 Check this thread, There's some links with the tool and hinge kits. Quote Link to comment Share on other sites More sharing options...
