Stumped
D N Monte
Hi everyone I'm trying to get my interior (dash) turn signals working on my all original 1972 Monte Carlo... can you help?
Printed circuit looks good and I have power to the bulb socket, and I have a new bulb...but still no light?
Is it the twist socket?
Funny, all the other lights work with same twist sockets?
Thanks, David
Have you tried swapping the twist socket with one you know that works from another spot on the cluster. You should be able to rule out whether it is the socket or not.
Just throwing this out there....Did the turn signals ever work? And are you sure the bulbs your trying to use are the correct for IP turn signals? Weird that all your exterior signal lamps light and blink, and your probe flashes in the twist socket.
Thanks.
Another ?, my seat belt light is not working. New bulb, but nothing?  I tried my test light at  and nothing.
I disconnected the wire under the bench seat, tried the test light and still nothing.
All fuses are working.
I know it's not a big deal, but I'd like everything to work :)
