71SS A/C Compressor brackets
Hey guys I bought a remanufactured A6 compressor and picked up some compressor mounting brackets from The Parts Place. After assembling everything it looks like the rear lower bracket is not lining up. Can somebody take a look at theirs and tell me if my brackets are installed wrong. I'm thinkin that maybe the exhaust mounting bracket is incorrect.
Thank you!
I believe the problem is that you are using the stock lower mounting bracket that is meant for stock manifolds and you are obviously now using headers.  I believe you can purchase one meant for headers.
2 hours ago, Dtret said:
That bracket mounts on the engine block Headers should not effect that( I think). But here are a couple pictures of mine.
Dennis is your lower bracket a factory bracket? It looks different than my aftermarket bracket.
