BobW Posted March 9, 2023 Share Posted March 9, 2023 My car is going in for vinyl top rust repair and paint soon. They are going to pull the windshield and rear window. Should I unplug the antenna coax from the radio, or is there another connection at the windshield itself? Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 10, 2023 Share Posted March 10, 2023 there should be a connection at the windshield itself. Tell them to be very careful when removing it that they don't break that connection when removing it. rob 3 Quote Link to comment Share on other sites More sharing options...
BobW Posted March 10, 2023 Author Share Posted March 10, 2023 20 minutes ago, Rob Peters said: there should be a connection at the windshield itself. Tell them to be very careful when removing it that they don't break that connection when removing it. rob Thanks Rob. 👍 I have to gut the interior for the roof repair. I think I'll pull the screws from the dash cap and take a look for it, maybe disconnect it my self, and leave it loose so they can slide it off if needed. 1 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 10, 2023 Share Posted March 10, 2023 You will want to warn them to not cut or break the line to the windshield when they are trying to remove the glass rob 1 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted March 10, 2023 Share Posted March 10, 2023 The antenna for the windshield is under the lower windshield trim. You need to remove that and then gently unplug the windshield. 1 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted March 10, 2023 Share Posted March 10, 2023 If you’re reusing the glass then, like said, be careful. If you’re replacing it the new glass will have the connection on it. 2 Quote Link to comment Share on other sites More sharing options...
