Chevyss Posted March 11, 2010 Share Posted March 11, 2010 OK!! I'm replacing the axles in the Monte. How to I find out just what I have and what would be the best axles to order. Do they come w/studs or w/o?? I'm guessing that it's a 8.875 axle and 30 splines. But you know how things go when you start guessing. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 11, 2010 Share Posted March 11, 2010 These will work for you Royce, Moser axles at Summit The flanges are thicker they will push your wheels out a bit. You may want to pick up these also, Strange C clip eliminators they can also supply you with the axles Quote Link to comment Share on other sites More sharing options...
Chevyss Posted March 11, 2010 Author Share Posted March 11, 2010 I have the eliminators on the axles in the car now. Don't suppose they can be used again. Or are the axles the same size?? Probably not!!!!!! Â Â Thanks Mike. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted March 11, 2010 Share Posted March 11, 2010 It is always better to replace the eliminators as they are pressed on the the axles. Getting them off in one piece then reinstalling them almost always gets you a leak. Â Andy Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted March 15, 2010 Share Posted March 15, 2010 i've always been told that C-Clip Eliminators on a street car are a big no-no. It was said that you go around a corner under power and you watch your axle and wheel go flying out. Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted March 15, 2010 Share Posted March 15, 2010 I went with weld on bearing housings and eliminated the need of anything holding the axles in place at the carrier. It's like you have a hybrid. Part Ford 9" and part GM 12-bolt. Super strong with lot's of confidence. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted March 15, 2010 Share Posted March 15, 2010 i've always been told that C-Clip Eliminators on a street car are a big no-no. It was said that you go around a corner under power and you watch your axle and wheel go flying out. Â Â ?????? Quote Link to comment Share on other sites More sharing options...
502ci Posted March 16, 2010 Share Posted March 16, 2010 I went with weld on bearing housings and eliminated the need of anything holding the axles in place at the carrier. It's like you have a hybrid. Part Ford 9" and part GM 12-bolt. Super strong with lot's of confidence. I have never heard them coming loose from the car but that on a hard turn as mentioned that's when they would most likely leak. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted March 16, 2010 Share Posted March 16, 2010 good point Allan... Â I put 8000 street miles on mine and no leaks..... Â The reason NHRA requires elimin's is so the axles don't come flyin' out (10.99 or faster)... Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted March 25, 2010 Share Posted March 25, 2010 Sorry, I meant what Allan said. I got myself mixed up. Senior moment. I retract all post refering to any of my posts about c-clip eliminators. Quote Link to comment Share on other sites More sharing options...
FASTSS454 Posted April 17, 2010 Share Posted April 17, 2010 I had been running the Strange Drag kit from 1990 until about 3 years ago when I switched over to their new style street strip kit. If your thinking about doing this be forewarned you need to cut the housing end tubes down. Â http://www.strangeengineering.net/newprod/StrangeA1033.html Photo circa 1991 Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 17, 2010 Share Posted April 17, 2010 great picture! Quote Link to comment Share on other sites More sharing options...
TN454Monte Posted April 17, 2010 Share Posted April 17, 2010 great picture! Â X2 Quote Link to comment Share on other sites More sharing options...
Chevyss Posted April 18, 2010 Author Share Posted April 18, 2010 x3 Like that launch. Finally got the Moser axles and c-clip eliminators installed. (I know no pictures it didn't happen) guess I'll post the bill. Hope they will hold. Next is driveshaft. Denny's Quote Link to comment Share on other sites More sharing options...
FASTSS454 Posted April 18, 2010 Share Posted April 18, 2010 Thanks, I loved surprising all those 5.0 Mustang guys back in the day. They were like [you said a naughty!] that bigass boat just blew my doors off. Quote Link to comment Share on other sites More sharing options...
FASTSS454 Posted April 18, 2010 Share Posted April 18, 2010 OPPPPS I guess I can't say W.t.f. here lol Quote Link to comment Share on other sites More sharing options...
