BOP will it work????
71 MONTE 4 YA
Will a BOP 12 bolt posi with 3:42 gears work in my 71 monte? Is it worth $300. The person selling it says it has been modified to work in a G-body but can be put back into a 68-72 A-body. I haven't talked to the person this is all from his ad. What possible modifications could he be talking about? Thanks family...... Rodney
Not sure what mods he may have done. But the 12 bolt in my monte is out of an a 70-72 Olds Cutlass... It fit fine except I had to have my drive shaft shortened... I think it's a heavy duty model...
Ummm...moving spring perches is kind of involved...I don't know what kind of experience you have...so fogive me if I am out of line...but cutting exsiting perches off and making sure the correct ones are welded on in the right spot seems pretty involved to me. I have not been out pricing rears, but I personally would look more for a direct fit.
As for the 3:42's I run them with a 27"tall tire and turn just about 3000rpm at 70
  • 2 months later...
Well I bought the BOP rear end. It has 12 bolts on the cover and 10 bolts on the ring gear. Is this bad? It has 42 teeth on the ring gear and it is posi. I do not plan on racing or building my engine into a powerful beast. Do you all think this will be ok for my use? Here are a few pictures:
Here is the mod the guy did to make the rear fit into the G-body Regal he had it in. He moved the perches to the top of the axle tubes
Are these the bolt in axles?
If all goes well, there wont be any more one wheel peel shiftershocked
The axles are not bolt in, those are the bolts that hold the backing plates on. The spring perches look like they are in the correct place for a Monte or any A/G body. What does it measure backing plate to backing plate? It should measure the same as your current one does.
I thought the perches sat a little bit forward of the axle housing on the Monte. I also thought the 12 bolt BOP rear Which is really a 10 bolt because it has 10 bolts on the ring gear had the bolt in axles. Someone correct me if I am wrong. I have really been searching all over the web trying to find more info on this.
Rodney, a good 4X4 shop resets perches all the time. They should be able to measure the angle of your drive shaft and calculate the perch settings on your rear end. They will also tell you if what you have will work, or will they need to use pieces from the old one.
BTW new perches are fairly cheap too.
I had perches done on my 74 IH Scout, and they turned out great.
Kevin
If it has 42 teeth it probably a 3.23 gear ratio. definatly a bolt in style should have 31 spline axles in it.
The guy that I got it from said it had 3.42 gears in it. How can I tell?
Count the nuber of teeth on the ring and on the pinion divide the number on the ring by the pinion. Say you have 37 on the ring and 9 on the pinion that would be a 4.11.
I would have to disassemble the carrier to see the pinion teeth right?
Put a wheel lug nut on one of the lugs, and using that as a reference point. Have a friend/wife/GF turn the drive shaft 1 complete revolution. Count how many times the lugnut makes a complete revolution. Example is, 1 turn of drive shaft and 3 and 1/4 in turn equates to 3.25 or probably close to a common ratio of 3.23.
Hope this helps
Kevin
Hope this helps
Kevin
It takes 3.25 turns of the driveshaft for one complete revolution of the lugnut. What do I have?
3.23 is a pretty good ratio for all around driving. You can also get 3.42 and 3.90 gear sets from aftermarket Richmond gears. They will both fit the posi carrier you have.
The axle spline count is most likely 28 as the 31 spline axle 12 bolt 'O' type are usually pretty rare. We can check all that when you bring it by. smile Jim
330 659 7117
Jim
J D RAce.com
