Decoding Engine ID#, Block and Heads casting #
Kane
I just find the Engine ID# V0226CRE and Block casting # 3970010, Heads casting# 3927186 I did a google search and it said the engine block casting # was a Late 1969 Corvette 350 4 bolt main High performance motor and the heads casting # said they were camel backs. I just want to know if this information is correct and if so what does it mean? The engine run strong and doesn't somke or burn oil. Any advice on performance upgrades for street/strip driving would greatly appreciated. Thanks
you have your self one nice block a heads back in the 60s and 70s the camel back heads And the corvette block with the wintage tray and 4 Bolt mains was the set up to have there's tons of hipo things to do to the heads and block and tons of aftermarket hipo parts ill let some one elce list some or ill get back on later I'm on my cell phone right now
This is what i get from your numbers.
ID# CRE 1970 350, 4 barrel TH350 trans
Block casting# 3970010
3970010....302.....69....4 bolt...Z-28 Camaro
3970010....327.....69....2 bolt...Trucks and industrial
3970010....350...69-80...2 or 4 bolt
So it could have been in a vette but It could be the original engine. Do the numbers before the CRE match your VIN number?
Head 3927186....69-70...302/350......Camel hump,64cc chambers,accessory holes
The could have 1.94/1.50 or 2.02/1.60 valves
These were the codes for the good 70 350
CTB - 350cid 4V w/manual (LT1)
CTC - 350cid 4V w/TH400 (LT1)
