Timing
robs70monte
I got back to work today on my truck i dropped the distributor in it at 10* before top dead center a tried to start her up and at first it tried but all i get is popping and some flames out the headers and carb i tried turning the dizzy while i cranked it and nothing im not 180 off im on the compression stroke what gives
details
chevy 350
old school points has good spark
268h cam installed at 2* retarded for top end(CAM HAS
4*advanced built in)
has a old school cast iron hi rise intake
headers
a 750 q jet off a buick 350
ditto Sounds like 180 0ut
Originally Posted By: robs70monte
finger on the #1 spark plug hole blew my finger off so it on the compression stroke
Originally Posted By: Sam (Bones)
then the firing order is wrong
ditto or your really not 10 degrees like you think you are and behind or ahead of things..
I got a story on timing... Changed the plugs and wires on my daughters 2000 Blazer the other day. 4.3L Vortec...
I thought it had a "Correct-a-cap" type cap... Nope... On the even side yes,,, The odd side is 3-1-5. Couldn't figure out why the stupid thing was missing so bad. crazy
