snomobeelr Posted November 26, 2012 Share Posted November 26, 2012 There is a small block on the passenger side Mounted on the core support behind the battery. Between the Battery and Radiator. There is a red wire from the harness to it. Is there supposed to also be a wire from the positive side of battery to it as well ? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 26, 2012 Share Posted November 26, 2012 yes, that's your power feed to the fuse block Quote Link to comment Share on other sites More sharing options...
bigtankjones Posted November 26, 2012 Share Posted November 26, 2012 Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted November 26, 2012 Share Posted November 26, 2012 The wire from the positive battery terminal to the junction block is a fusible link. There should also be another one from the negative terminal and grounded to the inner front fender near the battery. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted November 27, 2012 Author Share Posted November 27, 2012 Thanks Guys. So could I place an in-line fuse in there instead of a fusable link? Car isnt stock or Factory Restored. Anyone have a picture of the Bolt for thr battery tray mount to the Core support Braket and core support? I am in the process of putting it back together. I also got the steel wheel wells instead which I heard will need some tweaking. Thanks agian Quote Link to comment Share on other sites More sharing options...
wallaby Posted November 27, 2012 Share Posted November 27, 2012 A fusible link will handle power surges much better than a typical fuse. The inline fuse will tend to pop right away with any excessive current it sees, where the fusible link will happily hold up to some abuse for a period of time before it blows. Fusible link wire is easy to get at the auto parts store. I think that wire uses a 14ga link wire..grey in color. You can use solderless terminals to put one together, but I'd recommend soldering them anyway. While I was at it, I made up a couple of extras that I stash in the car just in case. I had one fry when I tried jump-starting the car once...don't want to go through that again. Quote Link to comment Share on other sites More sharing options...
