darn fuel gauge
wallaby
Just when you think it'll never happen to you: my fuel gauge has gone kaput. It worked fine yesterday, but today it's pegged beyond full...it's pointing at the 3 O'clock position. It doesn't matter if the key is turned on or off.
Before I start tracking this down, maybe someone else has been through this before?
Mine throws a fit every now and then and does the same thing Mark, it returns to normal after I run some fuel out of it(a day or two). It seems to only do it occasionally, Ive narrowed it down to when I fill it up completely, I know that doesnt help you much, I hate it
I had the exact same problem a few decades ago (man I'm getting old). One day I turned the ignition on and the needle went pass full all the way to 3 o'clock and stayed there. I'm pretty sure the fix was to re-establish the ground which attaches to the fuel tank brace.
Good luck
Welll, it sounded easy. LOL
It looks as if I have an open circuit somewhere between the trunk connector and ground. My mechanic says it's common for the "wiper" to break off of the sending unit inside the tank.
If I hook up a test light to the feed wire, it shows voltage and the resistance in the bulb sends the fuel gauge down to about 1/4 tank... seems like everything is in order except the sending unit.
I did a quick search for a replacement sender, and it looks as if they are all a 3/8" fuel line....but there is one listed that also has a 1/4" return line. I'd bet I need the one with the return, what with California smog and all...and it looks like there are more than 2 lines going to the tank. One of those might be a tank vent and not related to the sender, but I haven't pulled the tank to look.
Right now I'm just trying to find a replacement sender to hand to my mechanic.
What's your vote? Get the one with the return?
1971 SS454. CA car.
