D.E Posted September 13, 2013 Share Posted September 13, 2013 Those clips on the roof rail that o against the door glass what is covering them mine seem to be bare metal and I think that they have some sort of rubber coating.Could you use that coating that goes on handles of pliers called tooldip or something like that.I know OPGI sells them now for 20 something dollars but what else could you use Thanks Quote Link to comment Share on other sites More sharing options...
daberry Posted September 13, 2013 Share Posted September 13, 2013 That's what I used on my Camaro a few years back. It worked pretty well. The product I used was Plasti-dip. Dale Quote Link to comment Share on other sites More sharing options...
DaveC Posted September 13, 2013 Share Posted September 13, 2013 I used it... not quite as good as what GM used, it stayed kinda soft, (was not as dark, hard, or shiney black like the original stuff. Quote Link to comment Share on other sites More sharing options...
LostnFound Posted September 13, 2013 Share Posted September 13, 2013 Maybe it would also work on the do-hicky that you pull on to get the hood open? Quote Link to comment Share on other sites More sharing options...
daberry Posted September 13, 2013 Share Posted September 13, 2013 I would echo that it is not as hard as the original material but seemed to work fine. Â I've been thinking about using it for the hood release on my monte as well. Quote Link to comment Share on other sites More sharing options...
black07ss Posted September 13, 2013 Share Posted September 13, 2013 I wonder how some of that rattle can bedliner stuff would work? Quote Link to comment Share on other sites More sharing options...
daberry Posted September 13, 2013 Share Posted September 13, 2013 You know... that bedliner stuff would be closer to the hardness of the original material. On the downside most I have seen the bedliner stuff fade pretty quickly. Quote Link to comment Share on other sites More sharing options...
MC-71 Posted September 13, 2013 Share Posted September 13, 2013 How about Heat Shrink Tube. I'm sure it will work on the hood pull. I did my Tin Knockers Hammer years ago. Still on. Quote Link to comment Share on other sites More sharing options...
D.E Posted September 13, 2013 Author Share Posted September 13, 2013 Thanks I"ll try it and the shrink wrap sounds good too Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted September 14, 2013 Share Posted September 14, 2013 I also used Plasti-Dip and it worked well - I did have to redo it several times before I was happy with the result though (I was being picky). Quote Link to comment Share on other sites More sharing options...
