Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Twin Turbo "aspirations"
  • Please log in to reply
26 replies to this topic
#1 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
  • Occupation:Caterer
Posted 11 August 2016 - 06:02 AM
Hey all.
I've been researching plans to engine swap my 71 for a while now. Initially, I was considering a big inch big block, however, I've always wanted to have a twin turbo first gen.  So with patience and critical thought, I've decided I should forgo the original plan and just do what really want with my vehicle.
My plan is to build a big bock 454 twin turbo engine.  It'll start with a forged short block and build up from there.  I have not decided on the actual turbo setup yet, but I have some ideas.  It'll be a low boost build and keep it right around a mild 800hp, relatively speaking.
There will obviously be stages to this build.  First off, I'm thinking of a simple blow through setup.  There's a few places that offer good carb setups for what I'm doing.  Maybe down the road, I'll make the switch to EFI. In time, I may even increase the boost for more power as things progress.  I know this is impractical and will cost more money, but I also know I won't be satisfied at the end of the day, otherwise.  One thing I like is to be unique.  However, one of the foremost concerns is driveability.  I enjoy driving the vehicle, therefore, many decisions and components will be considered to keep its main purpose intact.  That being said, I may just go EFI to begin with, but I've heard good things about what they are doing with blow through carbs lately.  I'm not planning on blowing the budget and spending tens of thousands of dollars on this, but I will also not skim on the most important parts.
As things move along, I'll update this thread accordingly.  So, any thoughts? Perhaps, where should I start with a short block?
"If it can't be preached in prison, it shouldn't be preached."-me
#2 Mister
Mister
    If U stay ready...U dont have to get ready
  • Members
  • 90 posts
  • LocationMacon,GA.
  • Legal Name:Anthony Robinson Jr.
  • Occupation:Electrician
Posted 11 August 2016 - 08:31 PM
I say go for it! And why stop at 800...make it a cool 1000!
http://s1368.photobu...koeu0s.jpg.html
J.E.T. LIFE(JUST ENJOY THIS LIFE)
#3 Mister
Mister
  • Members
  • 90 posts
  • LocationMacon,GA.
Posted 11 August 2016 - 08:50 PM
If it were me I'd start with a good aluminum block or aftermarket iron block.
#4 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
Posted 07 September 2016 - 10:30 AM
First step in the build will soon commence.  I decided to spring for the EFI first since it is easily the best option nowadays for running turbo applications.
I went with the Fitech 1200hp EFI after much research, deliberation, and reviews. I'll be adding a surge tank to feed the fuel pumps for the conversion.  Once I get the EFI up and running, it will be time to add the turbo setup which I have not finalized yet.
#5 Mister
Mister
  • Members
  • 90 posts
  • LocationMacon,GA.
Posted 08 September 2016 - 11:20 PM
Awesome!!
#6 bigscaht
bigscaht
    Silver Member
  • Members
  • 1,961 posts
  • LocationHayward, Ca
  • Legal Name:Scott Floyd
  • Occupation:DJ
Posted 10 October 2016 - 01:23 PM
that's gonna be a fun ride
#7 WOES
WOES
    Member
  • Members
  • 14 posts
  • LocationTorrance, Ca
  • Legal Name:Jason
Posted 10 October 2016 - 08:16 PM
Sweet
Whether therefore ye eat, or drink, or whatsoever ye do, do all to the glory of God.
1Corinthians 10:31
#8 Mo's70MCs
Mo's70MCs
    I " WIN" nothing! Yay! Tripple
  • Members
  • 7,114 posts
  • LocationNorwalk, Ca.
  • Legal Name:Rod Marin Jr
Posted 11 October 2016 - 06:23 AM
Can't wait to see that bad boy. You know how we are.. pics and more pics. Good luck with the venture.
gallery_1189_9_1413157583_4055.jpgRod
"I swear officer, these quart jars are fuel".
#9 rtgz71
rtgz71
    Member
  • Members
  • 11 posts
  • Locationmanorville, ny
  • Legal Name:ron
  • Occupation:LEO
Posted 17 November 2016 - 02:33 PM
I am involved with a similar project right now, although a little more ambitious. 540, twin s475 BW turbos, probably a Lenco and a FAB9. What I have learned is the same as you...while the blow thru carbs have come a long way, there is very little room for a tuning mistake, so while EFI is more expensive to start, the first (inevitable) mistake with a carb will make up for it in parts. Also, your goal of 800hp will probably require you to detune it quite a bit. You double your power at app 15psi of boost, so if you make 600hp N/A you can figure 1000-1100 at 15 psi. 600hp these days is easy. Best thing you can do is start with a good aftermarket block and quality forged rotating assembly. The best part of this is it's pretty easy on motor at these lower levels....Good luck !!!
#10 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
Posted 02 July 2017 - 07:38 AM
Figured I should update this since I haven't and there's been some progress. I decided to convert to EFI using fitech .
Fitech EFI is performing properly as things get settled in. I switched out my ignition for better timing control under boost. In place of the HE I, I modified a TBI distributor, added an MSD coil and programmable 6al. Since I needed to add a CDI box anyway because of boost, it wasn't that much more expensive for the programmable box which does a better job controlling timing than the Fitech. Anyway, installed that and got it all dialed in to where I want it.
On to the fun stuff. I started mocking up the twin turbo setup. It's a cxracing hot side kit built for first gen big block chevelles. Needless to say, some fabrication required. New valve covers were ordered since my fabricated set doesn't clear. A few other minor clearance issues that are easily manageable. However, the major issue will be the steering shaft. It looks like I'll have to reroute using ujoints and new shaft sections. Besides that, charge pipes need to be fabricated, and turbo oil lines need to be ran, and it's pretty much ready to fire up.
Anyway, here's what's been happening the past week. Enjoy.
#11 GatorDog72
GatorDog72
    Brass Member
  • Members
  • 327 posts
  • LocationCentral New York
  • Legal Name:Ryan L Palmer
  • Occupation:Welder/ Fabricator
Posted 03 July 2017 - 05:44 AM
Very cool build! You have made quite a bit of progress. Looks like it will be a monster when it's done. What size turbos are those? Are you planning to run pump gas or methanol?
'72 Monte Carlo 489 Cubic Inch Big Block Chevy on Nitrous.
A work in progress....
#12 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
Posted 03 July 2017 - 09:47 AM
Thanks for the response.
I'm actually going to run e85. I built the fuel system up for it and turbos love corn juice. Those are Borg Warner S366 turbos with the 66mm inducer. I'm only going to run low boost, however, because this is still a street car and will remain that way. I don't want an all out race car.
#13 mymontesa70
mymontesa70
    Brass Member
  • Members
  • 286 posts
  • Locationmpls. minnesota
  • Legal Name:Brandon Landsberger
Posted 03 July 2017 - 10:49 AM
thats a wicked build. ill make sure to stay tuned to this one.
#14 Ian
Ian
    Webmaster
  • Administrators
  • 7,040 posts
  • LocationAustin, AR
  • Legal Name:Ian Novinger
  • Occupation:Truck Mechanic
Posted 19 July 2017 - 10:55 AM
Nice!
-- Ian
"Experience is a hard teacher because she gives the test first, the lesson afterwords."
"Pick battles big enough to matter, small enough to win."
#15 Vaughn
Vaughn
    Platinum Member
  • Members
  • 3,401 posts
  • LocationHigh River, Alberta, Canada
  • Legal Name:Vaughn Peoples
  • Occupation:Arborist
Posted 19 July 2017 - 11:05 AM
Very nice!!!
#16 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
Posted 21 July 2017 - 07:21 PM
The progress has been moving along slowly but surely. I have a temporary cold side mocked up until I can get to my fabricator and get some pipes properly bent. I have the steering shaft rerouted, oil lines finished, and everything fitting properly. I still need to wrap and silicon paint the headers, but I can't do that in the extreme heat and humidity we've been experiencing. 100°, heat index 115° because of humidity. That's causing a delay. It's very close, just still waiting on some minor things before the final assembly. My turbo blankets are on their way also.
#17 o_rod
o_rod
    Advanced Member
  • Members
  • 96 posts
  • LocationOntario, Canada
  • Legal Name:Bryan
Posted 25 July 2017 - 05:41 PM
Thats a gorgeous engine bay, In for the finale!!
Did you have to modify the Fitech 1200hp kit any to properly work with a blow through set up? I've been looking into the 600 hp kit and would like it to be future proof for the possibility of boosting later down the road.
#18 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
Posted 26 July 2017 - 05:22 PM
The Fitech 1200 (30012) is absolutely built for boost in a blow through style. There is also a 2x4 1200hp model (30064) and a 600hp model (30004) which are also built with boost capabilities. Make sure you purchase one if these Power Adder models if you plan on boost in the future. Each one also works fine while NA.
#19 Hisalone
Hisalone
    Member
  • Moderators
  • 240 posts
  • LocationOmaha, NE
Posted 31 July 2017 - 05:38 PM
Got it running.
https://youtu.be/7OFMPzH8Ujs
#20 71MonteCarloMD
71MonteCarloMD
    Gold Member
  • Members
  • 2,213 posts
  • LocationFrederick, MD
  • Legal Name:Rick Baker
  • Occupation:IT Projects Director
Posted 03 August 2017 - 04:47 AM
Video is no longer available?
Home Page
Message Forum
Members' Montes|Meet Photos
