Jared Richey Posted December 18, 2013 Share Posted December 18, 2013 A factory Vinyl Roof don't rust. The vinyl will rot away and the top will still be fine. Its when another top is put on on, and people try and save material and not properly prime and paint the top, then scuff and glue the vinyl top back down. Quote Link to comment Share on other sites More sharing options...
bigscaht Posted December 19, 2013 Share Posted December 19, 2013 exactly how i felt man!!! Quote Link to comment Share on other sites More sharing options...
jacob Posted December 20, 2013 Author Share Posted December 20, 2013 I'm going to be sure its done right when my new vinyl top goes down primed, painted, scuffed and glued. Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted December 23, 2013 Share Posted December 23, 2013 Did you find a used roof skin, or you gonna buy a Chevelle one? Quote Link to comment Share on other sites More sharing options...
jacob Posted December 24, 2013 Author Share Posted December 24, 2013 I bought 3 montes for the price of one I'm using the body off the best one on my cars chassis... Pretty much switching body's the new body had some rust in the top and floor where the other body I was going to use needed new quarters new trunk floor new top the outer wheel house rusted away from the quarter panels in places. I payed 1500 for another running driving car that I traded body's with and 2 incomplete parts cars witch I will be using one car to fix the top and the other has some nice trim parts. Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted December 27, 2013 Share Posted December 27, 2013 If I'd would have knew that, I would have sold you a 72 Big Block Body with NC Title to go on your frame, all this car needs now is the Trunk Floor, tail panel and Rear Window Channel. Quote Link to comment Share on other sites More sharing options...
jacob Posted January 5, 2014 Author Share Posted January 5, 2014 What primer and paint do you guys recomend I want to paint the under body the same color as the body. witch I have decided to do bluestone metallic it's a toyota highlander color and I just fell in love with it. I want it to be tough and look great I don't want it to chip or crack and more importantly no rust. Quote Link to comment Share on other sites More sharing options...
jacob Posted January 6, 2014 Author Share Posted January 6, 2014 working on cutting out all the spot welds. Â Â Quote Link to comment Share on other sites More sharing options...
jacob Posted January 7, 2014 Author Share Posted January 7, 2014 What primer do you recommend using on the under body I've heard of ppg DP90 epoxy primer being a good primer for the under body any opinions. Quote Link to comment Share on other sites More sharing options...
Leghome Posted January 7, 2014 Share Posted January 7, 2014 Any major manufacturer's epoxy primer would be good or POR15 in black Semi gloss is another good option. With POR15 no activator needed and you can use a brush on it and when it dries it is smooth like it was sprayed. At around $47 a quart it is a little less costly. Quote Link to comment Share on other sites More sharing options...
jacob Posted January 7, 2014 Author Share Posted January 7, 2014 Yeah I've used por 15 you have to be sure to degrease and use there metal prep or that por 15 won't stick unless you get it on your skin. Could you prime the under side of the car scuff it and then use por 15 and a uv protectant? That way if the uv gets chipped off or the por 15 gets scratched or what ever it has a long way to go before it can reach bare steel and you could do body color over the por15. Quote Link to comment Share on other sites More sharing options...
Leghome Posted January 7, 2014 Share Posted January 7, 2014 The POR 15 is not a UV protectent it must be top coated. I used it on my frame when I had the engine out tow years ago and it still looks as it did on application. no UV rays hit the bottom side of the car. Quote Link to comment Share on other sites More sharing options...
jacob Posted January 16, 2014 Author Share Posted January 16, 2014 What do I need to do to be able to remove the inner rockers and braces the reason I ask is that the outer rocker and inner rocker sandwich the floor pan. The braces are just about ready to come lose the 4 spot welds on each end are all thats holding the first two braces on. also im wanting to be able to weld the cleaned up braces and inner rocker to the floor pan and then weld it in as one piece floor bracing and inner rockers. I have taken a few measurements nothing has moved so far do I need to do more bracing or need a frame jig to to remove the braces and inner rockers? Quote Link to comment Share on other sites More sharing options...
jacob Posted January 16, 2014 Author Share Posted January 16, 2014 What would move if you were to take out the braces and inner rockers? I was thinking it would be best to get the braces and inner rockers welded to the new floor that way it will go in as a single piece thinking that would be easier to install and weld. And while I had the inner rockers off I could clean and por 15 inside the rockers. Quote Link to comment Share on other sites More sharing options...
jacob Posted January 19, 2014 Author Share Posted January 19, 2014 Would removing the inner rockers and braces need additional bracing or need to be on a frame jig would like to remove the inner rockers and braces and clean them up and weld them to the new floor and then install. Quote Link to comment Share on other sites More sharing options...
