Jared Richey Posted August 11, 2014 Share Posted August 11, 2014 I have a good working electric fan and want to put it on the Red Car in my signature. The Radiator I have is basically the same size and thickness of an original copper one for a Big Block, but it is a Griffin Radiator/Aluminum. I have fan, but no mounting brackets. Can someone lead me in the right direction of where to get mounts for the fan, looks like to me mounting it is very important as you don't want to cause damaged to your radiator. Quote Link to comment Share on other sites More sharing options...
footballubet Posted August 11, 2014 Share Posted August 11, 2014 How about something like these. Quote Link to comment Share on other sites More sharing options...
cudax Posted August 11, 2014 Share Posted August 11, 2014 Jegs has a bunch of electric fan mounting kits too. Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted August 11, 2014 Author Share Posted August 11, 2014 Thanks everyone, there on the way. Quote Link to comment Share on other sites More sharing options...
Vinniepooh Posted August 11, 2014 Share Posted August 11, 2014 Not sure if you are leaving on the stock fan and shroud or going electric only ? I just bought these two items for a car that I was working on. The shroud fit great on the 28" X 19" Howe aluminum radiator. http://www.summitracing.com/parts/flx-53524/overview/ http://www.summitracing.com/parts/flx-398 Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted August 11, 2014 Author Share Posted August 11, 2014 That fan looks identical to the one I have, and it was given to me, it actually came off of a 72 Monte that had a 468, but when Kevin's uncle bought it he put a shroud and fan back on it. Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 14, 2014 Share Posted August 14, 2014 I just used these: LINKY They can't be any easier, and easy to undo also. Autozone, Pep Boys, etc has 'em. Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted August 14, 2014 Author Share Posted August 14, 2014 I just used these: LINKY They can't be any easier, and easy to undo also. Autozone, Pep Boys, etc has 'em. Yep those are the ones I ordered. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 14, 2014 Share Posted August 14, 2014 I used those on my last radiator, they ended up rubbing a hole thru the core, I don't recommend them Quote Link to comment Share on other sites More sharing options...
badddoin Posted August 14, 2014 Share Posted August 14, 2014 I had those on a 4th. gen that i had electric fans on. They eventually killed the radiator, as well. Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 16, 2014 Share Posted August 16, 2014 Oh really? These have the neat foam pads with them...did you have problems with the same setup? I ran mine for about 3 yrs and then relocated my fan; couldn't even tell where the old set had been. Quote Link to comment Share on other sites More sharing options...
72MC Posted August 16, 2014 Share Posted August 16, 2014 These are the ones I used on my now Ex Monte. http://www.summitracing.com/parts/sum-329725/overview/ Of course, they fit perfect with the square appearance of a Be Cool Radiator. Mark, I thought about getting the ones you listed but didn't like the way the fan would be mounted. JM2C - Dave Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 16, 2014 Share Posted August 16, 2014 those are also the same ones I used Quote Link to comment Share on other sites More sharing options...
