GatorDog72 Posted March 14, 2016 Share Posted March 14, 2016 I'm building a chevy 355 for my daily driver and wanted to use stamped, non-roller rockers. Is there a special way to measure the length of the push rods? I have done it before with roller rockers, never had to with the stamped type. Is it the same procedure? I would love to go with roller rockers, but I don't know of any that will fit under stock valve covers for sure. Quote Link to comment Share on other sites More sharing options...
BigdaddyT Posted March 14, 2016 Share Posted March 14, 2016 Roller tip rockers with stock nuts not poly locks will fit stock valve covers 1 Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 14, 2016 Share Posted March 14, 2016 I have Comp cam roller tip rockers under my stock valve covers. I used a Erson cam and Comp roller rockers also with stock GM push rods. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 14, 2016 Share Posted March 14, 2016 the procedure will be the same here's a great video on measuring for push rod length 2 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 14, 2016 Share Posted March 14, 2016 Wait you mean my roller rockers won't fit under my stock size chrome valve covers? Darn it more parts to buy. I'll add that to the list. Quote Link to comment Share on other sites More sharing options...
Its Just Me Posted March 15, 2016 Share Posted March 15, 2016 I don't know that there is a truly accurate way to determine the rotation c/l of the ball socket of a stamped steel rocker arm. I believe this is your question, yes? I've wondered the same thing. Easy enough on a roller "tip", but not so much at the ball socket. Without the rotation C/L of the ball socket it's a little difficult to find 90 degrees to the valve like the video shows. Will the stamped tip leave a consistent mark on the valve stem through a full lift cycle? If so, could you adjust pushrod length for the thinest mark, or centermost mark, kinda like the old fashioned way? I don't know if this will work on stamped arms though. I wish I had an answer for you. Hopefully, someone else has an idea. I've heard that the Comp Ultra Pro Magnum roller rockers are a low profile, but not sure they will clear stock covers...maybe worth a call to comp. Good Luck. Scott Quote Link to comment Share on other sites More sharing options...
