Montecarlo71
Stuck fuel pump rod
So I have a 71 mc with a 454. THe fuel pump push rod is stuck. Want to put a electric fuel pump and eliminate the mechanical one. How do i accomplish this? Fuel pump suggestions and install? Or at least find a way to get the rod out . There are no bolts in front of the block holding it in place and I do not have a welder lol
Share this post
On the block, under the fuel pump rod is a threaded "plug". Remove that so when you free up the pushrod it will pass through the block.
Try spraying the rod with some penatrating fluid. In your pics, the bolts spoken about are not there. Spray the penatrating oil in those holes. Most likely that's how the rod rusted in the block in the first place and why that part of the engine has excessive oil on it.
Then using a heat source, torch, propane torch, heat up the rod and block a few cycles. Try and loosen up the rod with long nose vise grips locked onto the rod.
Share this post
Ok thank you will due. So your saying the 2 holes on the front of the block is y it was rusted? How will I no the love on the cam is still good?
Share this post
I'm not saying that's why. Just possibly/most likely why.
Glad to hear she runs. That most likely means that the rod moved enough to let the cam turn. So it may not be as bad as thought. 😁
Once freed up, if in ok shape you could hold the rod against the cam and crank the engine. The rod should go in and out of the block to check the fuel pump rod lobe on the cam.
Share this post
Right on ya been working on it all day not freeing up. So just gonna plate it off and go on to an electric pump. Thank you for your insight, very inlighting.
Share this post
when you turn the engine over does the rod go in an out. if not then either it is sort of in a neutral position and stuck or you have a worn cam lobe. with s tock fuel pump it would preload the rod to ride firmly against the fuel pump lobe.
Share this post
I would try to get the rod loose. I would hate to think of it coming loose at high rpm and shooting around breaking the block.
Share this post
