Tmac Posted January 18, 2023 Share Posted January 18, 2023 Got my frame back and ready to start putting the front suspension back on. Any advice for nominal settings for everything? I'm not sure of I should go back with the original settings I recorded, it was shot to put it mildly. 2 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted January 18, 2023 Share Posted January 18, 2023 Install the upper a-arm spacers to the locations they were removed. Excellent place to start. Everything else set for the front wheels to be straight. With the weight of the car on the ground you want a difference of about 1/8" from the inside of the front of the front tires as compared to the inside rear of the front tires. Should be close and you will be able to drive your restored ride to get a professional alignment. Keep the pics coming! Quote Link to comment Share on other sites More sharing options...
Tmac Posted January 18, 2023 Author Share Posted January 18, 2023 Okay, thanks! I can do that! Quote Link to comment Share on other sites More sharing options...
stangeba Posted January 19, 2023 Share Posted January 19, 2023 Better Ft end alignment specs from 1990. FYI Quote Link to comment Share on other sites More sharing options...
420ponies Posted January 19, 2023 Share Posted January 19, 2023 Just like MC1of80 says, you can drive it to get aligned. I drove mine 60 miles to "the guy" open headers and all. No wear on new tires ( maybe the rear, burnouts on the way), but was just fine. Looks like the snowball effect happened to you too. Glad to see another coming back to the road !! 2 Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted January 19, 2023 Share Posted January 19, 2023 As they said, 1/8" toe in and 3+ degrees of positive caster. You also want -.25 to -1.5 degrees of camber. After the car is on the road you can tune the alignment based on how it feels using this guide: https://www.ridetech.com/tech/suspension-tuning-guide-high-performance-vehicles/ Quote Link to comment Share on other sites More sharing options...
Montemedic Posted January 19, 2023 Share Posted January 19, 2023 Depending on what your doing with your Monte, Bruce posted a great article and Cody a chart for high performance vehicles. Thank you both for sharing this info. 1 Quote Link to comment Share on other sites More sharing options...
Tmac Posted January 19, 2023 Author Share Posted January 19, 2023 2 hours ago, 420ponies said: Just like MC1of80 says, you can drive it to get aligned. I drove mine 60 miles to "the guy" open headers and all. No wear on new tires ( maybe the rear, burnouts on the way), but was just fine. Looks like the snowball effect happened to you too. Glad to see another coming back to the road !! I did get in deep and quickly!! Lol Quote Link to comment Share on other sites More sharing options...
