Not a Monte but does start with "M"
DragCat
Sorry Rob, couldn't resist 🤣 Since I was Monte-Less over the winter I decided to do the electric fan/radiator upgrade on the Mercury....I was very pleased with the results on the Monte and they were on $ale. I also swapped out the aftermarket gauges on the steering column, originally I had white face gauges and it just irked me being a triple black car. Also since Dennis started a trend with pictures with feet and its been carried on by others I didn't want to be late to the party 🤣
The swap was pretty straight forward since I had already done one , except the temp sensor for the fans. I had no "open" ports for the sensor except removing a petcock in the block which I didn't want to do. Also didn't want to splice into a ignition on power wire in the harness (which I did on the Monte)You can barely see in the feet/gauge picture 2 toggle switch's. I took out a few fins in the a/c vent (who runs a/c when the top is down 🤣) One is for ignition on volts and the other is for bypassing the temp sensor signal (since there is no sensor ) and it just grounds the sensor input and cuts the fans on. Clevelands are hot running to begin with and being in Fl it doesn't help.
  • Like 8
Nice!
My wife had a Red 73 Cougar 351 Cleveland 2BBL, nice car but it was stolen, never to be found.
  • Sad 1
13 minutes ago, stangeba said:
Nice!
Ive been looking for a 71/72 factory 429 Cougar for awhile now, I call it my unicorn search 🤣
28 minutes ago, DragCat said:
I have big dreams 🤣🤣
He did too he wanted a boss 429 but they are out of sight. He going in a different direction on his 27 coupe he's putting a 2700 4 cyl race motor. Builder said it'll do 8000 rpm all day long 😳
Yea, I looked for more than 2 years, zip....... So decided to go the Monte route. Can't complain, very happy with my Monte and found this site. Life is good 😁
