Whons Posted April 1, 2023 Share Posted April 1, 2023 Does anyone know the most accurate way to check the stall speed of the torque converter that's in the car. I've read about brake stall and flash stall. I don't want to ruin the transmission. Any info would be greatly appreciated. Thanks Wayne Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted April 1, 2023 Share Posted April 1, 2023 No real "accurate" way other than what you already know. That's why manufacturers give you a "range". Like a 1800-2200, 2200-2500 stall, 3000-3500 etc. Depending on individual car set ups what a converter will actually stall at. Old school, before "high tech" converter manufacturers we used to install vega converters into th350s and 400s for a high stall converter. They would be like 1000rpm stall in a vega but 2500-3500 rpm stall behind a small block or big block. 7 Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 2, 2023 Share Posted April 2, 2023 5 hours ago, MC1of80 said: No real "accurate" way other than what you already know. That's why manufacturers give you a "range". Like a 1800-2200, 2200-2500 stall, 3000-3500 etc. Depending on individual car set ups what a converter will actually stall at. Old school, before "high tech" converter manufacturers we used to install vega converters into th350s and 400s for a high stall converter. They would be like 1000rpm stall in a vega but 2500-3500 rpm stall behind a small block or big block. I put a Vega converter in my 400 sb Monza, worked very well. 5 Quote Link to comment Share on other sites More sharing options...
S.Maug Posted May 9 Share Posted May 9 did the same thing. vega converter in my sb 400 80 monza. worked exceptionally well. Quote Link to comment Share on other sites More sharing options...
S.Maug Posted May 9 Share Posted May 9 building a 75 vega right now. going to put my 69 buick 430 in this one. 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted May 9 Share Posted May 9 1 hour ago, S.Maug said: did the same thing. vega converter in my sb 400 80 monza. worked exceptionally well. I did the same years ago on my 76 Monza. 1 Quote Link to comment Share on other sites More sharing options...
