BBC Pulley Squeal, Water pump Pully ?
snomobeelr
I've heard the squeak , but just noticed the water pump pully appears to be off a bit from the crank pully. Barley noticeable. It only squeaks when I hammer on it.  If I remember correctly I had these pulleys on the small block 350 that used to be in the car. The water pump pulley is 3995631A0.  Has anyone had this issue ?
Tighten the belt. New belts stretch after a few heating and cooling cycles and they wear into the groove of the pulleys.
If there was an issue with alignment you would be throwing belts. Especially when hammering it.
Its not the Power steering pump  belt. Its difficult to get a picture to come out with the way the belt looks " wonky" from the crank to the Water pump pulley. It doesn't make noise when starting or under regular driving. Only full throttle. At 1st I wasn't sure if it was the belt or the air going into the carb.
