454 will not run at 8 degree has to be around 25 initial to idle smooth
Rich 71
Hi Rich.
What is done to the engine? 8 degrees is way too low. Usually 10-14 initial with about 29-34 at 2500 rpm is a good starting point. Each engine has a "sweet" spot with timing that it likes.
Is the vacuum advance hose, to the distributor, removed and plugged?
ok I'll set it around 15 and tune some more,. advance disconnected and plugged at carb . has stock cam for 71 SS Thanks for the replies
Try 15° and go from there. I went through the same thing on my 402 trying to set it at 8-10° and it wasn’t going to happen. It’s happy at 16
