Guest Posted March 18, 2005 Share Posted March 18, 2005 Hi, I know this has been asked before and i've done multible searches for an answer, and im still confused I had the tank media blasted and it's goin back in this weekend hopefully....I have 3 vents.. 2 on either side and one in the middle of the tank.all at the top edge...the fuel line comes off the sending unit. But where do those vent tubes belong.it seems to me they were just hooked together when it was removed.I do have the venting fuel cap. Thanks RCR Link to comment Share on other sites More sharing options...
kcgreg Posted March 18, 2005 Share Posted March 18, 2005 I had mine out last fall to do the same thing you are. I haven't been under there since then but if I remember right there is a vent "Box" behind the back seat that reaches to the bottom of the car where the three vents from the gas tank you talked about hook up to. There is also a bracket that helps mount and seperate the vent hoses. I will check my records and see if I have a picture of it, if so I will post it. Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 18, 2005 Share Posted March 18, 2005 hey guys, her is a pic of my tank i droped a few weeks ago I will look at my tank and let you know tonight which goes where. alex Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2005 Share Posted March 18, 2005 Thanks guys, Appreciate it! Alex, your tank is the same as mine...IS that your build sheet?. RCR Link to comment Share on other sites More sharing options...
Katman Posted March 18, 2005 Share Posted March 18, 2005 I had mine out awhile ago, cut the lines and left them in place until I ran the new lines so that I would be able to get it right. I will have access to the underbody to take a picture later next week if you still need help. Mark Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 18, 2005 Share Posted March 18, 2005 yes it is lovely isnt it here is a better picture lol my tank has 5 tubes that come out of the tank. two of which are fuel out and fuel return and the other three are vents. Link to comment Share on other sites More sharing options...
Phil Posted March 19, 2005 Share Posted March 19, 2005 Hey Alex if your fiance cooks as good as my wife I'd get that build sheet off the stove now. Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 19, 2005 Share Posted March 19, 2005 ok the two that come out of the sending unit are fuel out "large line" and return "small line" the other three hook up to the vent tower "the three that are grouped together on the pass side of the tower" then the one by its self on the drivers side of the tower hooks up to your vapor line. that runs on the driverside frame rail, alex Link to comment Share on other sites More sharing options...
alex's72fgmc Posted March 19, 2005 Share Posted March 19, 2005 its in my safe now to keep it from her and my daughter lol thanks phil lol Link to comment Share on other sites More sharing options...
Guest Posted April 17, 2005 Share Posted April 17, 2005 Say, I was wondering about that vapor collection thingy behind the rear seat....does that need to be there? If I have it taken out will my car blow up or catch on fire? I noticed it has 4 lines running out of it. I haven't traced them all, but I did see that two ran to the upper corners of the fuel tank. The guy that is working on my car said I didn't need it and we already took out the canister from the front. Someone help me please? Link to comment Share on other sites More sharing options...
alex's72fgmc Posted April 17, 2005 Share Posted April 17, 2005 the vent tower is there for venting fumes from the tank and buring them off in the engine. "for better fuel mileage. depending on if your car had emissions equipment which texas does have emmisions requirements "depending on location" which if the car came with it it must keep that emmisions system installed unless it qualifies as an exempt vehicle. all in all its up to you. alex Link to comment Share on other sites More sharing options...
kc8oye Posted April 21, 2005 Share Posted April 21, 2005 From what I understand.. only '72's have that vent tower behind the rear seat. I took one out my '72 body I scrapped.. and there was no where to put it on the '70 body shell I bought from leo. Link to comment Share on other sites More sharing options...
stangeba Posted April 21, 2005 Share Posted April 21, 2005 My 71 has it Link to comment Share on other sites More sharing options...
