vince Posted September 28, 2009 Share Posted September 28, 2009 Has anyone restored these before? They are in good shape except for the black in the back ground. any ideas? Link to comment Share on other sites More sharing options...
FRANKIE T. Posted September 28, 2009 Share Posted September 28, 2009 Place them face down on 3" painters tape and spray the black from rear of emblem Link to comment Share on other sites More sharing options...
tom71 Posted September 28, 2009 Share Posted September 28, 2009 I painted mine from the front (all black) then used some very fine grit emry paper to take the paint off the letters. Put the paper on a block of wood and take the paint right off. Came out brand new. Link to comment Share on other sites More sharing options...
CrazyDavey Posted September 28, 2009 Share Posted September 28, 2009 Place them face down on 3" painters tape and spray the black from rear of emblem As Frankie said just protect the face as best you can. I wouldn't be too concerned, if you have a rag with some carbon tet (gumout) handy you can carefully wipe the face of the chrome clean. One other thing you can do is go to a good model shop and get some liquid masking tape and brush it on the chrome surface. After the black has dried you can just rub it off.....MORE PIC'S!!!!! love your car...Dave Link to comment Share on other sites More sharing options...
7tonemonte Posted September 28, 2009 Share Posted September 28, 2009 I sprayed mine black and wiped the chrome off with a towell and reducer while it was still wet. It worked real nice actually. I had no pits or anything in mine, just faded black. I did the same thing with the rear emblems for the rear body panel. It was quick and easy, and is holding up nicely so far! Link to comment Share on other sites More sharing options...
vince Posted September 28, 2009 Author Share Posted September 28, 2009 fine grit emery paper, liquid masking tape, towel and reducer, All are excellent ideas. I was thinking around the same lines only using acetone or paint thinner. Anything special for the paint? or will plain high gloss rattle can paint work? Link to comment Share on other sites More sharing options...
7tonemonte Posted September 28, 2009 Share Posted September 28, 2009 Youll be fine with spray bomb! I used it on my emblems, and paint thinner will work just fine too. Spray cans arent all bad! Link to comment Share on other sites More sharing options...
CrazyDavey Posted September 28, 2009 Share Posted September 28, 2009 fine grit emery paper, liquid masking tape, towel and reducer, All are excellent ideas. I was thinking around the same lines only using acetone or paint thinner. Anything special for the paint? or will plain high gloss rattle can paint work? Vince I don't think they were high gloss, usually most trim was done in what they call 60% but a good semi-gloss or satin would work good..... Link to comment Share on other sites More sharing options...
vince Posted September 29, 2009 Author Share Posted September 29, 2009 Thanks guys I will give it try this week and let you know how it turns out. Link to comment Share on other sites More sharing options...
vince Posted October 3, 2009 Author Share Posted October 3, 2009 Thanks Everyone for your advise. I used the technique above and everything turned out good. I was very happy with the outcome Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 3, 2009 Share Posted October 3, 2009 Thanks Everyone for your advise. I used the technique above and everything turned out good. I was very happy with the outcome so where are the pic's????? Link to comment Share on other sites More sharing options...
kc8oye Posted October 4, 2009 Share Posted October 4, 2009 i was bored one afternoon in the winter last year.. so I grabbed a can of rust'oleum satin black and a modeling paint brush, and hand-painted the black with a very fine paint brush... it took a while, but it came out REALLLLY nice. Link to comment Share on other sites More sharing options...
vince Posted October 4, 2009 Author Share Posted October 4, 2009 Tim at first I tried it that way but my eye sight is getting weaker with age. Here is the out come. Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 4, 2009 Share Posted October 4, 2009 look good to me Vince...any progress on the car?? Link to comment Share on other sites More sharing options...
MADMAC Posted October 4, 2009 Share Posted October 4, 2009 Looks good! I guess I'm going to have to redo mine now. Link to comment Share on other sites More sharing options...
Chevyss Posted October 5, 2009 Share Posted October 5, 2009 Those emblems look great. I'll ask how do you get them off the car. I haven't tried it because I thought they might break. I know how the one on the back panel comes off but not the sail panels. Thanks for everyones info. Link to comment Share on other sites More sharing options...
vince Posted October 5, 2009 Author Share Posted October 5, 2009 It's been a while since I took them off, but if I remember I used a shop rag against the car and preyed them off with a plastic putty knife. It's Probably not the best methiod to do, but it worked for me. The pegs on the emblems seem to have a spring loaded wire that expands once in the hole. Link to comment Share on other sites More sharing options...
Ian Posted October 6, 2009 Share Posted October 6, 2009 If I recall there are nuts on the back of them.. Link to comment Share on other sites More sharing options...
7tonemonte Posted October 6, 2009 Share Posted October 6, 2009 Just barrel clips on the ones in my car. Pry gently would be my only suggestion. Sometimes you can get the strapping from a box,the hard flat plastic kind, and work it in behind and pull out on the emblems. Link to comment Share on other sites More sharing options...
