Jared Richey Posted October 20, 2009 Share Posted October 20, 2009 Dropped the Monte off at JP Automotive Performance and Racing about 5 pm today to install a 6 point roll bar. I'm 18, so no fancy removable door bars, but it will be looped over the back seat through the package tray so the rear seats will be installed. The shop found it very interesting that my car on the street is running 7.40s already with bascially an out of the box 750 Holley DP carb. They said with a different bigger carb, and few more tricks, she'll be knocking 7 flat all motor. Anyway everything is $600 installed including all the materials. The best part...done in 3 days or less. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 20, 2009 Share Posted October 20, 2009 Dropped the Monte off at JP Automotive Performance and Racing about 5 pm today to install a 6 point roll bar. I'm 18, so no fancy removable door bars, but it will be looped over the back seat through the package tray so the rear seats will be installed. The shop found it very interesting that my car on the street is running 7.40s already with bascially an out of the box 750 Holley DP carb. They said with a different bigger carb, and few more tricks, she'll be knocking 7 flat all motor. Anyway everything is $600 installed including all the materials. The best part...done in 3 days or less. way to go Jared!!! that sounds great, yeah the swing-out stuff adds a lot of cost (doubled the cost of my kit) but I'm too old to be crawling over bars..I wish I was closer, I'd lend you my new Prosystems DP and it would blow you away. My best 1/8 was 7.48, I took the new carb out of the box, bolted it on and ran a 7.19 first pass.... Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted October 20, 2009 Author Share Posted October 20, 2009 Can you give me the info on that carb please? part number, cfm? I was told I need atleast an 850 Doublepumper Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 20, 2009 Share Posted October 20, 2009 Can you give me the info on that carb please? part number, cfm? I was told I need atleast an 850 Doublepumper it's a custom build Jared so there's not really a part number. I called Patrick at ProSystems (several other guys on the forum have his carbs), told him what I had and he bulit a carb to that spec. He told me to bolt it on, don't change anything and try it out. Then give him a call and discuss it (haven't done that yet). He said he could pretty much guarantee me 2-3 tenth improvement, so far I have 3.5 (I only got to make 1 run)! It's a 920 cfm....no choke housing....50cc accel pmps frt/rr....045 sqrtr frt/rr...6.5 pri PV....84 prim jet....92 sec jet... expensive but I don't know how I would have gotten that kind of improvement for less....very, very happy with it (plus it looks cool!!) ProSystems 727-490-5717...they're in MI. Quote Link to comment Share on other sites More sharing options...
Kevin Wiles Posted October 20, 2009 Share Posted October 20, 2009 jareds roll bar is actually going to be made of pvc pipe. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 20, 2009 Share Posted October 20, 2009 jareds roll bar is actually going to be made of pvc pipe. hope he uses NHRA approved glue.... Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted October 21, 2009 Author Share Posted October 21, 2009 jareds roll bar is actually going to be made of pvc pipe. Yeah, some of that metal NHRA approved PCV pipe. also known as steel tubing. Quote Link to comment Share on other sites More sharing options...
TommyP Posted October 21, 2009 Share Posted October 21, 2009 I think that the rule book says it can be made out of PVC as long as the bar that goes behind the seats is glued in and not removable. Just kidding Dave. Quote Link to comment Share on other sites More sharing options...
dbreese Posted October 21, 2009 Share Posted October 21, 2009 I think that the rule book says it can be made out of PVC as long as the bar that goes behind the seats is glued in and not removable. Just kidding Dave. Now that's funny!! David Quote Link to comment Share on other sites More sharing options...
Kevin Wiles Posted October 21, 2009 Share Posted October 21, 2009 jared is planning on pouring cement mix down into the pvc to give the illusion of steel. if he pays me 100 u.s. dollars i will not tell the drag strip tech official. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 21, 2009 Share Posted October 21, 2009 jared is planning on pouring cement mix down into the pvc to give the illusion of steel. if he pays me 100 u.s. dollars i will not tell the drag strip tech official. it doesn't matter, the tech will find something to complain about....it's their job.... okay...okay...Tommy, I'm welding in the bar!!! I just won't pick up any hitchhikers from now on.....and Dave, buddy, ..you're going to have the same problem with that new motor!!! Quote Link to comment Share on other sites More sharing options...
Chevyss Posted October 21, 2009 Share Posted October 21, 2009 $1000.00 to get 2-3. Cost money to go fast. Quote Link to comment Share on other sites More sharing options...
TommyP Posted October 22, 2009 Share Posted October 22, 2009 Dave I'm just kidding you because it's become such a hot topic. I wouldn't weld it and I don't think that you should either unless the guys at tech make you change it. I personally really like the way you have it now and would hate to have you change it if it's not necessary. Tom Quote Link to comment Share on other sites More sharing options...
502ci Posted October 22, 2009 Share Posted October 22, 2009 Dave should throw some roll bar padding on it and they will never see it, I would... Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted October 22, 2009 Author Share Posted October 22, 2009 Roll Bar is done and LOOKS SWEET! I'll post some pics tomorrow. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted October 22, 2009 Share Posted October 22, 2009 man that was fast Jared...can't wait to see it.... Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted October 23, 2009 Author Share Posted October 23, 2009 Only too them 2 days. Dropped it off Monday night, got it back Wedneday evening. Labor, Materials everything...6 point. $600 More pics here on myspace. Bottom of page five and on page 6. Also check out the other pics. http://viewmorepics.myspace.com/index.cf...6759&page=5 Quote Link to comment Share on other sites More sharing options...
MADMAC Posted October 23, 2009 Share Posted October 23, 2009 Awesome Jared, Thats really gonna stiffen the car up! More burnt rice, please sir! hehehehe.... Quote Link to comment Share on other sites More sharing options...
dbreese Posted October 23, 2009 Share Posted October 23, 2009 Looks great Jared!!! Were you able to keep the armrests? Did they run the rear bars through the package tray? Sorry bout that I just looked at the rest of the pic's They did a great job!! Thanks David Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted October 23, 2009 Author Share Posted October 23, 2009 Looks great Jared!!! Were you able to keep the armrests? Did they run the rear bars through the package tray? Thanks David To be 100% sure of being ok at bigger NHRA tracks, NO ARMREST..oh well. And the bars are run through the package tray. The rear seats will be able to be installed. This setup is goo to 6.49 in the 1/8 mile. I'm thinking 10 in the 1/4 Quote Link to comment Share on other sites More sharing options...
MADMAC Posted October 23, 2009 Share Posted October 23, 2009 Hmmm... interesting... I never even thought about the armrest clearance. I wonder if the swingout down bars would clear them? You say to make sure that it passes at other tracks; what size tubing did you use? Would tech inspections be that different from place to place? Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted October 23, 2009 Author Share Posted October 23, 2009 Hmmm... interesting... I never even thought about the armrest clearance. I wonder if the swingout down bars would clear them? You say to make sure that it passes at other tracks; what size tubing did you use? Would tech inspections be that different from place to place? The door bars have to run the way they are to pass at NHRA tech, just depends on the tech offical though, some would pass u, some would not. Its whatever size tubing you have to have. Same as any other bar. I don't know off the top of my head. But the door bars directly would hit the armrest and the door would not shut. Basically to be legal, the bars can't loop around the armres, they have to be the way they are. At my local track, things you can get away with would never fly at an NHRA track. Quote Link to comment Share on other sites More sharing options...
MADMAC Posted October 23, 2009 Share Posted October 23, 2009 Originally Posted By: MADMAC Hmmm... interesting... I never even thought about the armrest clearance. I wonder if the swingout down bars would clear them? You say to make sure that it passes at other tracks; what size tubing did you use? Would tech inspections be that different from place to place? The door bars have to run the way they are to pass at NHRA tech, just depends on the tech offical though, some would pass u, some would not. Its whatever size tubing you have to have. Same as any other bar. I don't know off the top of my head. But the door bars directly would hit the armrest and the door would not shut. Basically to be legal, the bars can't loop around the armres, they have to be the way they are. At my local track, things you can get away with would never fly at an NHRA track. Alright, I gotcha Jared, I guess sacrificing the armrests isn't really that bad. Quote Link to comment Share on other sites More sharing options...
Ian Posted October 23, 2009 Share Posted October 23, 2009 Looking good Jared! I remember when me and my buddy put ours in our Old Cutlass it really stiffened it up. Quote Link to comment Share on other sites More sharing options...
502ci Posted October 23, 2009 Share Posted October 23, 2009 Looks great... Have you tried climbing in the back yet... Quote Link to comment Share on other sites More sharing options...
